Gts-t 33 Sunroof Computer Exhaust Coolerect $15999
When they started to glow and crazy sparks, was the battery still in the car and connected to POS and negative? What sort of battery is it? (Lithium, lead acid, etc?) Is it possible you stuffed up the jump start and managed to get both POS and neg cables on a dead short through the skyline? Check the resistance again, then disconnect the power cable on the alternator, and then measure that same resistance from POS pole to earth. Then measure alternators POS pole to alternator body (with cable disconnected). Do the same on / with the starter motor.
Hmmm.. trying to theorise what else it can be. Still don't understand how sparks were being thrown, and the clamps/connectors touch points started to glow. It was like putting a spanner across the terminals. More troubleshooting soon -
Those two circuits would end up in the same looms from near cluster/stalk all the way to the SMJ from memory, so fault could be anywhere between cluster/stalk area down to the SMJ, and even in the SMJ. Other possible f**kery is some cars for compliance in Australia had extra resistors added to dash / headlight wiring to alter dash bright ness, so could be some dodgy free electrons floating out of that area if it's done in this car.
More amps is also useful in modern cars when diagnosing, since just having canbus networks alive will draw over 5amp to power the car, and that's before you actually "turn the electrics on". Yep, I've flattened a few batteries while doing reverse engineering when I've forgotten to put the cars on the charger. Have also had one of those Victron chargers Dose bought die and start spewing high voltages out of it too. That's a sample size of 1 though. Charger lasted about 18 months before doing so.
