hello there
Just wondering if the dude with the black hr31 skyline browses this forum. Just had a 'legal' race with him in a silver VL.. damn ur car is slow considering the clapped out auto vl wasnt letting u get away too easily hahaah :P:D
So who wants to own upto it? Asked what he was running all I got was RB25.. hahahaha tell me more and ill race you in my line :D
Anyways anyone know him?
Cheers
P.S. Im pretty tanked so excuse my shitty typing:)
edit: P.P.S. The waving of the hand was quite hilarious too.. hope i dont see u round :)
Edited by Mumbo#5
https://www.sau.com.au/forums/topic/89550-hr31-cairns-black/
it was a coupe. Pretty clean and well looked after. His tune is fairly above stock cause of the puffs of smoke on gear changes.. must be running something half decent running more fuel through it.. But yeh cant remember the exacts cause i was pissed at the time. And for the VL i was in with a f**ked auto it didnt go too bad against him.. we didnt try stall it up and take of hard cause of the poor auto. But meh.. just trying to found out more about it
look zaffa time for rant u f**king wank:
Ok.. since im registered on a SKYLINE forum.. its generally accepted that I drive a skyline right?.. so WTF AM I DOING DRIVING A CLAPPED OUT VL??
I was NOT the one driving. My SOBER mate was driving, I was in the passenger seat, hence how I asked the driver what he was running. I would NEVER drink drive cause I know how bad it is. SO GET UR FÜCKING FACTS RIGHT U SEWER RAT.
/end rant
edit: Its amazing how misconstrued the information can be. All I want to know is what was done to the R31.. some people these days.. damn...
Edited by Mumbo#5
BBQ: Ill roast you anyday.. mwuahhahah
nsm034: Do you have the white R34? cause I know murry i think his name is has the black one 34GTT plates or the like i think.. I drive a silver one lol.. chrome mags lowered and kinda stock looking..
below is pic of my POS before i got new front bar bonnet mudguards etc
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
