hello there
Just wondering if the dude with the black hr31 skyline browses this forum. Just had a 'legal' race with him in a silver VL.. damn ur car is slow considering the clapped out auto vl wasnt letting u get away too easily hahaah :P:D
So who wants to own upto it? Asked what he was running all I got was RB25.. hahahaha tell me more and ill race you in my line :D
Anyways anyone know him?
Cheers
P.S. Im pretty tanked so excuse my shitty typing:)
edit: P.P.S. The waving of the hand was quite hilarious too.. hope i dont see u round :)
Edited by Mumbo#5
https://www.sau.com.au/forums/topic/89550-hr31-cairns-black/
it was a coupe. Pretty clean and well looked after. His tune is fairly above stock cause of the puffs of smoke on gear changes.. must be running something half decent running more fuel through it.. But yeh cant remember the exacts cause i was pissed at the time. And for the VL i was in with a f**ked auto it didnt go too bad against him.. we didnt try stall it up and take of hard cause of the poor auto. But meh.. just trying to found out more about it
look zaffa time for rant u f**king wank:
Ok.. since im registered on a SKYLINE forum.. its generally accepted that I drive a skyline right?.. so WTF AM I DOING DRIVING A CLAPPED OUT VL??
I was NOT the one driving. My SOBER mate was driving, I was in the passenger seat, hence how I asked the driver what he was running. I would NEVER drink drive cause I know how bad it is. SO GET UR FÜCKING FACTS RIGHT U SEWER RAT.
/end rant
edit: Its amazing how misconstrued the information can be. All I want to know is what was done to the R31.. some people these days.. damn...
Edited by Mumbo#5
BBQ: Ill roast you anyday.. mwuahhahah
nsm034: Do you have the white R34? cause I know murry i think his name is has the black one 34GTT plates or the like i think.. I drive a silver one lol.. chrome mags lowered and kinda stock looking..
below is pic of my POS before i got new front bar bonnet mudguards etc
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
