Whassup dudes
I made some of these so I had real white light not piss yellow lighting for my car. So I decided to make a quick guide for all the peoples that want white light for their cars!
What ever lights you want to replace you will need bulbs that fit that type of socket. This will work for all low voltage applications that are 12V in cars. Interior lights, numberplate lights, parkers, festoons ect
. You will need:
your old globes you want to replace
LEDs: CAT. NO. ZD0194 they are like $2 each.
Resistors part number: RR0559 they are about $2 for eight.
Solder
Soldering iron
Pliers
Wire cutters
1. Cut the positive side of the LED 5mm from the base. Cut a resistor 5mm from the resistor base.
2. Solder the 2 together with the short sides overlapping
3. Test the LED with a 12V DC power supply to make sure it works
4. Take your old light globe and carefully break the glass by squeezing it with the pliers, remove all the shards of glass and remove the filament between the 2 wires in the globe
5. You need to solder the LED/RESISTOR assembly to the inside wires of the light globe. This is a fiddly job and you will need to tin the joints to make it easier.
6. The LED/RESISTOR needs have the correct polarity to work. But every globe is different so if you solder it one way and it doesn’t work then you have got it backwards!
Once you have made one put it in the socket and see how it goes!
Follow the step by step photos if you get stuck. The results are awsome!
https://www.sau.com.au/forums/topic/89601-led-lights-for-any-socket/
there is a picture of the light working next to the original globe ^^^ up there :P
I will take a couple of pictures when i get back to sydney. I am in the land of fireworks and porn at the moment :D
cheers dudes
there is a picture of the light working next to the original globe ^^^ up there :D
I will take a couple of pictures when i get back to sydney. I am in the land of fireworks and porn at the moment :)
cheers dudes
Might as well post some porn pics up as well while you're at it lol.
  • 4 weeks later...
A quick note from the land of fireworks, porn (and pathetic pollies) -
You can now buy 'wide angle' LEDs. The light isn't as directional as normal LEDs. Not sure if Jaycar have them, but LEDSales do.
Try http://www.ledsales.com.au/cart.php?target...y&category_id=2
You can also buy bulbs already set up with the LEDs set in the correct plug. Not sure where from, but I've seen them on eBay.
Hey Nic can you convert the rear of my ceffy to look like the current model statemen rear?
Cool.. beers on me give me a ring :(
Done and Done!!
I have some High quality cardboard and some slightly used gaffa tepe and a photo of a statesman rear.
I know where your car is parked. I will do it when you are not there and call it my cristmas present to you.
:P
note for longevity of LED's might be helped with a bit higher resistor value. i think most are specified for about 20ma, but at 12V with the 300ohm the led is getting 30ma (and upwards when can running).
470ohm resistor might be a bit better
12V with a 300Ohm resistor is closer to 40mA. Jaycar sell the Bulb fittings seperately so you can add the LED's of your choosing but they are pretty expensive. RS components sell Complete LED lighting replacements for incandecsant lighting in cars (except of course your mainbeams)
Example. As far as the LED's focused light, I've seen a couple of tricks used by people to disperse the light more evenly, lightly sanding the exterior of the led with some garnet paper seems to work alright and also filing the top of the dome of the LED package so that it is flat or concave will work fairly well too. Also if buying White or blue LED's from jaycar especially, get them all at one time and test them at the store if possible (most Jaycar stores Ive been to have a small LED tester) because different batches from different manufacturers can be a quite noticably different color.
  • 3 weeks later...
"LEDs: CAT. NO. ZD0194 they are like $2 each."
"I got the LEDs and resistors from jaycar electronics."
...just called up Jaycar.....they're more like $3.95 each now:(...still wanna try it out..haha
last time i was at jaycar i saw these:
http://www.jaycar.com.au/productView.asp?ID=ZD0480
http://www.jaycar.com.au/productView.asp?ID=ZD0482
im pretty sure they had replacement globes for other things (like the ones ur trying to make in this thread) so might be worth to check out before trying the diy way
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
    • Most driving should* be done on one side of single lane divided roads. In the RHD world, you drive on the left side of the dividing line and the road is probably cambered equally on both sides. So your side of the road slopes away to the left. The same is true for the LHD world, just everything swapped to the other side and opposite slope. With a perfectly neutral, straight ahead wheel alignment designed to drive straight on a perfectly flat surface (or at least one that is level on the left-right axis, even if it has some slope in the fore-aft axis) you will not be able to drive on a cambered road without the car wanting to drift down the camber. You will need to add steering input in the opposite direction all the time. This is annoying. The solution has always been to set the camber and/or the caster to produce a continuous turning force in the opposite direction of the camber. The car will drive straight on the kind of camber for which it was set up, presumably as described in the top paragraph. But.... when the car is set up this way, as soon as you get into a lane, usually on a multi-lane surface road or highway, where the camber is not as presumed during setup, the car will usually pull to one side. In the RHD world, if you are in the fast lane on a big divided road, you are probably on the opposite camber compared to what the car was set up for (ie, sloping down to the right) and the combination of the setup and that camber will make the car want to go right pretty hard. Even a perfectly flat lane will tend to want to go right. There's no getting around it. Civil engineers who know their stuff (which is not an assumption that can always be made) will attempt to keep the variation in camber across a multi-lane road as small as possible, and if they can will attempt to make the fast lane as close to flat, or even cambered in the same direction as all the other lanes. This takes a lot of planning for drainage, control of levels, ability to deal with the elevation changes that occur at road junctions, etc etc. So it's not trivial to get it right. When they do make it work, then the annoyance is reduced, along with tyre wear, fuel consumption, etc. In theory, the civil engineers are supposed to worry about those aspects of road design also. * This used to be true, but now with very large highway systems, even just multi-lane surface roads running everywhere, it is less true now than it was, but the old assumption is the basis for describing the phenomenon, so let's just run with it for the moment.
    • I think the consensus was that's normal. Sloped road surfaces or something? I remember @silviaz went through this before. It might be one of those things you never notice until you pay attention to it.
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
