Clutch is in. Its a heavy duty full organic face clutch. Grabby, and bites well.
Still waiting for the injectors.... Nengun keeps putting the despatch date back.. :P This sucks. And also hopefull the datalogic group buy goes well too. NOt sure how long it will take to have that delivered. Will make the tuners job so much easier.
  • Replies 333
how long ago did you order? i paid for mine 2 weeks ago nearly and i got a email today that the order is complete and items being shipped. that was for 12 740's nismo.
Did you get that email too? i cant get acces to the site ? is it down for u too?
no email saying they have been shipped yet, and 5-6 weeks is rediculous. Maybe I should have got them from Greenline, as apparently they are really quick. Then again, I';ve had stuff from nengun only take 4 days..
N1 oil pump - 2 weeks
Powerfc - 5 weeks
Camgear - 4 days
Not to stray off topic too much, but I think it basically depends on availability. Cam gears are cheap and popular, so I would expect a supplier to hold quiet a bit of stock. More expensive and unique items, I wouldn't, because who knows how long they would have to sit on them before sale.
For the record I ordered some Greddy Front Extension Pipes through Nengun. It took just over 8 weeks for the order to be sent from Japan, and three weeks to clear customs. All up, almost exactly 3 months. I was in no rush, and Nengun kept me informed (delay was due to JP holidays and Greddy having to actually make the item), thankfully :D
ohh baby. trust dumps. have you fitted them yet lucien? if not can i come and fondle them at some point before you put them on? I'm really keen so see some in person.
  • 1 month later...
damn.... I just got my car back...
On 95ron fuel and 14psi, with this setup, I made 223rwkw and 450nm or torque...
This really sucks... If so pissed off!
Does anyone have any ideas why so low??
The stock turbo made 210rwkw and 420nm or torque at 12psi!
Edited by The Mafia
Mods To date -
600x300x75 FMIC
Garret GT30r with a 0.63 rear standard manifold
Full partitioned 4 inch intake, with a VH45 AFM (90mm)
Full exhaust - split dump, and 3 - 3.5 - 4 inch exhaust with a HiFlow cat
Walbro 250l Fuel pump
Nismo 550cc injectors
PowerFC and Datalogit
The best fuel we have here is 95ron...yeah I know, it sucks. Mackay is a shit place for that sort of thing.
Edited by The Mafia
The stock turbine A/R of the RB25DET is 0.63. The GTR's have the 0.42.
I am almost 100% sure that the VG30DETT turbine A/R is 0.63 also but I will have to confirm tomorrow.
Edited by 3lit3 32
Next tank I will fill up with 95RON and see how much ign. I need to pull out.
Going from BP98 to BP ULP 91 I had to pull out 7 degree's in 4th to stop ping.
Mafia, you are running the GT3076R .6comp cover? or?
Edited by Cubes
Cubes - Its a VG30 ex housing, and a .7 comp cover
Miller - Clutch is 3100 pounds..Definately not the clutch
Don't need a pressure regulator, rail pressure was fine
Got cam gears, didn't make a difference..
you're saying 5-7rwks... dude, I remember someone posting with the same setup pulling 250 - 260 rwkw... I don't understand why mine is reading so low..
James how do you know this... lol Wipe your chin. :D
Mafia, so you don't know the gt30 specs? There's 3 basically... GT3071R, GT3076R, GT3040R.
You are right.. there was only really 1 person that made 270rwkw with the same setup, there was that one bloke with the horsepowerinabox turbo that made 260rwkw with 20psi on a rb25 turbine housing.
Then there's Bass Junky that made 250rwkw with 14psi and 260pon cams, and now there you with roughly the same power also, well considering your running crap 95ron.
hrmmm.. Makes me wonder if these ppls who have cracked 260-270rwkw's have either ran an aftermarket exh. manifolds or possibly even dropped the static comp ratio so they can push some decent boost in to it. Bass Junky's wouldn't take any more than 14psi.. ping. :(
Edited by Cubes
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
