Mercedese Benz Rb20 Conversion
fReak32
 Share
hi i rooted the torque converter in my auto box in my 32 the other day and decided that it was time for a manual, so i brought a half cut. i also got given 6 liters of hot house green auto paint and four litres of clear. then i got to thinking, i have an old merc 280sl 1967 model down in the shed and then it struck me PROJECT!!!!. So im going to put the spare rb20 in the merc with the auto box and a new torque converter then paint it hot house green. if anyone has any sujjestions ideas or comments on the convertion painting or anything related (like you think its a gay idea and i should find something better to do with my time) your posts would be much apreciated.
Hey fReak32,what sort of literage of paint is required to paint the whole car?
What kind of paint is it,and what kind of gun do you use for the job.:D
I am trying to collect some information of painting because i am going to try my hand at it.
It would be a good conversion with the paint to match.Ive seen an old merc with a 13b turbo rotary engine in it.Yours will be that much more different.You could even get an article going on here or in a magazine at the completion as being ''probably'' the first RB20det merc in the country if not the world. B)
Edited by Trust33
you should be able to paint a car with about five ltrs. i use acrylic laquer as its much more forgiving than 2 pack, with acrylic you will need the paint and about the same again of clear gloss then you need primer surfacer. i use a scorpion gravityfed gun and i have used cheap guns before and not been able to tell any diference, although i am only a hobbiest painter, not a pro.
Sounds good.
Keep us posted!
So where are you from?
Edited by Trust33
def post pics! the engine conversion will be awesom. No need for rb25 or 30, compare the power of the rb20 to the stock 2.8 and you'll see the rb will be great.
the ol pagoda roof 280 6cyl makes ~170hp compared to the ~215hp RB20det (not to mention easy mods from exhaust etc). The merc weighs not much more than a 32 skyline also.
not sure about the hot house green tho! get the engine in it and running before you go painting it green!
having some time off to get my other gearbox in my 32, auto 2 manuel convertion hard enough. but im not losing enthousiasm. front cut got hear other day and all looks good. no friggin centre vent though, why do they always brake, damn vents
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
