If HICAS is playing up, just get rid of it. It's too messy trying to fix it as most mechanics have no idea what it is or how it works.
I like the idea that I'm controlling the rear end, not some computer correcting me while I'm correcting it, and it's correcting me while...... you get the idea.
If you'r having problems which you THINK are caused by the HICAS you shouldfind some one with the software to diagnose it correctly and the knowhow to fix it.
You should only think about disableing it if you are a serious drifter or very fast around a track.
at least half the problems mentioned in this thread most probably have nothing to do with the HICAS
  • 9 months later...
Don't automatically assume the rear end "vague/wandering" feeling is due to the HICAS. I locked out my HICAS, and during the job found that the rear tie rods were rooted. The play in the rods were almost as much as the HICAS movement!
Advice - R32s are getting on in years - check all rods, bushes and knuckles for play and replace as necessary. The parts aren't expensive and it's amazing what difference it makes.
I have a problem where I can't enable my hicas diagnostics because my steering wheel isn't sitting straight. it's like 1 whole notch on the steering bolt to the right. But god damn if I was driving straight and the rear kicked out like that I would definately not drive it till i got it fixed, Hope you know what your doing about 'locking your HICAS' because I guess as Gav said, there's a chance it's not even that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
