I did my non type m to type m brake upgrade over the weekend as I got some 4 spotters for free of my boss, however I didnt get the type m rotors.
Everthing went on fine I had a little trouble bleeding the brakes but every thing seems fine now the brakes seemed really firm until I turned the car on and went for a blat. The brakes have to be almost on the floor before there is any retardation I assumed that the smaller stock rotors wouldnt be a problem as it would just be similar to running worn brake pads?
I also used the pads that were with the 4 spotters rather than buying new ones as I wasnt planning on doing the upgrade till I had the funds for the set of types front rear and new pads.
1. Should I buy a set of new pads and see how they go (dont really want to do this as it may only slight help but not fix the problem)
2. As the pedal feels very firm when you pump it up, have I not bleed the brakes correctly? (I printed of the s14 manual and followed it after searching for hours on end)
3. Should I try and get some type M rotors as the non ones are to thin?
4. take it to a brake place and confuse them with the whole type m non type thing and end up spending heaps of cash replacing brake master cylinders, getting the 4 spotters rebuilt etc because they dont know what there doing
https://www.sau.com.au/forums/topic/89701-type-m-brake-upgrade-probs/
what rotors are you using?
you cant use non turbo rotors on Turbo 4 spot calipers as the rotors are to thin , change to the r32 GTST rotors as they are thicker and they are the direct fit for that caliper....
Edited by urbanoperations
thanks dude but Ive got turbo non type m rotors Im going to change them over now anyway
You might also want to check which size your master cylinder is.. it's stamped on the side.. gts-t is 15/16
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
