I did my non type m to type m brake upgrade over the weekend as I got some 4 spotters for free of my boss, however I didnt get the type m rotors.
Everthing went on fine I had a little trouble bleeding the brakes but every thing seems fine now the brakes seemed really firm until I turned the car on and went for a blat. The brakes have to be almost on the floor before there is any retardation I assumed that the smaller stock rotors wouldnt be a problem as it would just be similar to running worn brake pads?
I also used the pads that were with the 4 spotters rather than buying new ones as I wasnt planning on doing the upgrade till I had the funds for the set of types front rear and new pads.
1. Should I buy a set of new pads and see how they go (dont really want to do this as it may only slight help but not fix the problem)
2. As the pedal feels very firm when you pump it up, have I not bleed the brakes correctly? (I printed of the s14 manual and followed it after searching for hours on end)
3. Should I try and get some type M rotors as the non ones are to thin?
4. take it to a brake place and confuse them with the whole type m non type thing and end up spending heaps of cash replacing brake master cylinders, getting the 4 spotters rebuilt etc because they dont know what there doing
https://www.sau.com.au/forums/topic/89701-type-m-brake-upgrade-probs/
what rotors are you using?
you cant use non turbo rotors on Turbo 4 spot calipers as the rotors are to thin , change to the r32 GTST rotors as they are thicker and they are the direct fit for that caliper....
Edited by urbanoperations
thanks dude but Ive got turbo non type m rotors Im going to change them over now anyway
You might also want to check which size your master cylinder is.. it's stamped on the side.. gts-t is 15/16
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
