Mine use to squeek I used silicon spray on the clutch leaver, i think it is called some thing like that, anyway under the car remove the rubber plug in the gear box the get someone to push the clutch in and out the find the squeek spray the noisie joints. try not to get any on the clutch plate as it will slip and might burn out. the squeek might not go away straight away but give it 24 hours to work its way in.
I hope that makes some sence!
:(:D :D :D
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-133517
  • 1 month later...
What is that component that people refer to when you change your cluth that gets rid of the squeaking noise??
Is it the Thrust bearing (locating in the gearbox). Or something similar.
Thats what makes it squeak right?
I will be upgrading my stock clutch (that squeaks like a bitch every morning) soon and want to make sure the mechanic attends to it at the same time..
Any advice would be great.
Regards
Rob
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-185178
Regards
Rob
My standard clutch squeaks as well. I'm getting a brand new Daikan heavy duty installed today so I'll let you know if it still squeaks. I doubt it will though. I'll also ask the mechanic what causes it.
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-185890
Hey 2fardwown,
Yeah that would be good... (I think it just needs lubrication, but you can't get to it very easily from the outside.. the best time to do it is when you install a new clutch).
Keep us informed..
Regards
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-186053
Mine creaks too! Isn't that funny, I 've got an aftermarket clutch... 2500pounds ceramic multibutton. awesome clutch. it creaks tho' when the pedal is depressed.
I have also noticed tyhat when my car is on idle i can hear this squeaky noise. I place my foot on the pedal just a bit, say depress it about 20mm and the squeakin stops. hmmm...
Any Ideas????
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-186640
Squiggle San,
The creaky noise is just the levering mechanism. nothing to worry about. The whirring sound when your foot is off the pedal is the thrust bearing - nothing to worry about there either. The bearing will outlast your clutch & when it's replaced, it's routine to replace the thrust bearing. My BigDatto does the same. Don't sweat it.
Sayonara.
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-186645
So what exactly is it that makes it squeak???
It does it every morning for me and does not go away until 30 minutes of driving.
Really annoying.
I just want to make sure I fix it, the same time I get a new clutch.
Regards
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-187839
Mr Datto, dank you vely march!
I only had my clutch replaced not that long ago. I have alos noticed that if i don't have enuf revs the thing bounces. is this due to the heavier plate.
it happens all the time when i'm going up my drive. don't want to rev it too much or it will lite up.
soyanara.....
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-188773
The fork pivot ball can sometimes snap away from the lower threaded section, pressure from the fork ensures that the two pieces will never separate and the squeaking comes from the two halves on some occasions.
I was told this by the owner of a performance workshop and when I questioned the validity of the information, he opened the drawer of his desk to reveal 5 new threaded pivots waiting for cars with this complaint.
Apparantly the part costs stuff all and is the same for both 31's and 32's.
33's I'm not sure on but I think he told me they were all the same aswell.
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-189116
  • 2 months later...
well, my little Nissan Pulsar hatch ('90) has a squeaky clutch too! I've just started watching Initial D, so for a bout a week i was going a bit crazy with the down shifting, using the clutch a HEAP more than normal, usually if i'm just coming up to a red light or something, i just thro it in neutral. But i started down gearing everything, see how quick i could do it (no where near as quick as some of the Best Motoring vids i've seen tho) :)
anyways, started squeaky after this liberal use... So it's not something that i can attack with a can of WD40 and crawl under my steering wheel to get to the pedals? I need to take something apart??
cheers.
https://www.sau.com.au/forums/topic/8971-squeaky-clutch/#findComment-320899
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
