So....what is wrong with my RB26?
Recently rebuilt by a engine builder with very suspect abilities. Completed 2000klm since rebuild including 4 oil changes. Running standard computer and standard boost. Rev limit is 8500.
Last 1000klm since running in finished have been a practice day at Wakefiled Park, a race meet at Oran Park and a race meet at Wakefield. In the last race at wakefeild I heard a knock on the last lap, finished the cool down lap and parked it.
The problem - there is a knock/tap in the motor. rises with revs
Oil pressure is normal (great)
Compression test results:
# - Dry test - wet test
1 - 10.5 kg/cm2 - 12.5 kg/cm2
2 - 12 kg/cm2 - 14 kg/cm2
3 - 12 kg/cm2 - 14 kg/cm2
4 - 12 kg/cm2 - 14 kg/cm2
5 - 12 kg/cm2 - 14 kg/cm2
6 - 11.5 kg/cm2 - 13.5 kg/cm2
Battery was boosted by a running car, engine was dead cold. No leakdown test
The noise sounds like it is coming from the top of the motor, maybe at the front or maybe I am imagining it. I put a screwdriver on the head next to my ear, and looked like a person with a screwdriver in my ear.
Anyway....lets have some educated guesses about what is wrong...answers to come sometime in the next few weeks when I get around to pulling it out.
https://www.sau.com.au/forums/topic/89720-what-is-wrong-with-my-rb26/
  • Replies 59
Duncan ,
It doesn't sound good mate , at a guess ( wild one at that ) i would say its a big and bearing , usualy one at the rear ( number 6 ) but you have a built engine so who knows if they checked clearances or not when they assembled it .
Compression on number one is very suss for a built engine as well as number 6 .
when you say wet test ai would assume you mean you put oil in the cil and heaps of it by the look of the resaults .
The comp test shoul be done on a warm engine and the throttle fully open .
Do a leakdown test it will give you a bit more info ( more reliable ) .
Does the knock get louder as it warms up ? Is it there when you first start it cold ?It could be a lifter or even an injector but my money is on a big end , but i hope i'm wrong .
yeah I wasn't shy with the oil....
Will actually get hold of a leak down tester at some stage but it wont help decide if I have a head or ring problem will it?
The knock is there from cold, not noticably noisier when warm. But I didn't run it up to temp today I dont want to do any further damage.
Bearing clearances were checked at the rebuild and they suggested standard size bearings which i was a bit surprised about I thought an older crank that had been machined might need oversize bearings. Unfortunately I didn't measure the clearances myself :)
Injector is interesting....when can an injector get noisey? I might throw another one in and see if there is any difference to the noise.
What can fail in a lifter? got any pics to edumacate me?
I have a leakdown tester but you will need a compressor to do the test , i can do for you if you like and i maybe able to give you a more educated guess as to whats wrong with it .
If its a bearing you will do more damage to the crank by running it but if you pulle it out you should change the crank with a new one anyway , if you spin the bearing then conrod through the block is possible .
If the crank was machined they would have used undersize bearings .
Injector can be noisy warm or cold .
A lifter can be come noisy when the clearances grow , there nothing wrong with the lifter , just bigger clearance . you can check with a filler gauge but you need to take the rocker covers off .
The lower comp on the 2 cil maybe because they had the valve clearances to tight ( to have a quiet engine ) and the valves are starting to burn a little .
Did you check comp before ?
You are correct in saying a leakdown test wont tell you if it leaks for valves or rings but it will still tell you more than a comp test .
To much oil in the cil thats the reason comp went up so much ( you made the combustion chamber smaller ( like having higher comp ratio ) .
Edited by wrxhoon
Did you check for woodpeckers inside before u put the block back together? Hope it's not anything serious :)
BTW this was funny....but I didn't post it.....SAU stuffing up or have I been ha><0r3d?
Duncan ,
I just thought of another possibility , just make things abit more complex , could be a gudgeon pin as well , depending on what they used , pistons and circlips or spirolocks , one of them may have come off !!! Then the knock you hear could be the gudgeon pin hiting the bore , you said it sounds like coming from the front didnt you ? That will explain the lower comp on number one as well , the circlip could have scored the bore .
Hard to say without hearing it and knowing how / what they used in the build .
i can say with certainty that it's not a big end bearing... i would definately look into the woodpecker idea though. they can make a noise quite similar to bearing knock as their beaks aren't compatible with the cast iron RB block...
also, could be tinitis from standing around Niels race car or other hearing damage caused be the screwdriver in your ear (you did put the handle in you ear right?) or a combination of the two problems. and actually you have no problem at all. except for the permenantly damaged hearing which is preferable to another RB26 rebuild...
feel better duncan?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
