hello guys,
i have heard that Skylines have lots of power and potential but on stock, the handling characteristics aren't anywhere near the little cars built for handling like an Integra Type R or FTO.
Guys, any suggestions to make a R33 GTS-T handle better?
Would it be to tweak the suspension setup,springs and such?
any help would be greatly appreciated.
thank you in advance :)
https://www.sau.com.au/forums/topic/89731-suspension-setup-for-handling/
Umm that is a really hard question to answer.
Yes a skyline is heavier than an integra type r or fto and so has a disadvantage there. But on the other hand its a very predictable, rear drive car with double wishbone suspension all around and a limited slip diff which is a pretty good starting point.
If you want great handling in a r33, check out this thread and get Gary's kit http://www.skylinesaustralia.com/forums/in...showtopic=85467
There is no doubt with this stuff in the car you will beat any integra or fto around a track :)
or even a BMW M3, like i did, with an otherwise stock R32 GTS-t :D
I beat your time round a skidpan tho :P
Yes you will axe me on a proper track, but its not the point!
Do what duncan says on this one dude, just dont bloody go low! That will stuff ya.
hello guys,
Have a look at the R33 GTST Whiteline and Bisltein suspension Group Buy thread
I think most of your questions are answered there, if not ask away and I wil do my best to answer.
:) cheers :P
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
