Hi Mate, My Full Engine Rebuild cost $6500.00. This Included all the good gear, & the block was O ringed etc... PM me if you want all the specs/parts.
The extras cost (Turbo/manifold/fuel/tuning) $$$, but I got some parts very cheap, cause I shpped around and didn't hurry.
Cheers
Chris
  • Replies 48
Another quality job. Good to see that the stock cam'd RB25 heads pumping great power without the need to spend $$$ on em  :)
But you will never know it's true potential, till you spend the $$$ on them :lol:
Just think how much power can be had with a good set of cams and some porting :huh:. You can make the same power, using less boost, better response and less stress on the engine.
around 10-12k in total?
Yeah around 12,
New Garrett GT30R - $1560.00 del from Sydney (I got this from a forum member, but won the bid on Ebay where it was alot cheaper than his asking price on SAU)
New HKS Lowmount Manifold - $900 del from Sydney.
Nismo 550cc Injectors - (Nengun) around $950 delivered
OS Giken Twin Plate $1800.00
Apexi PowerFC (Nengun) around $950.00 del
Splitfire Coil Pack - $560 - del -SAU Group Buy
Bosch 044 & surge tank setup in Boot - $1150approx Fitted.
HKS BOV $380.00 del from Japan Supplyer
$4000 spent at RacePace to install the Turbo/wastegate/Manifold/Injectors/tuning etc..
$400 - Setrab 19 row Oil Cooler & Perma-cool relocation Kit
$2270.00 Whiteline/Bilest/- Complete Suspension Package from Sydneykid's group buy.
$500 - GTR Bootlid & WING (included immaculate carbon fibre wing inserts)
$400 - Nismo 300km/hr speedo/ - dash full unit
Soon to spend more to finish car - Full Respray (except enginebay) in Polar White with a pearl through it.
Plus another $500.00 to install the suspension setup.
F**k This really adds up when someone aks you what you have spent.
Then It will be finished and Hopefully just spending on 5000km services (and Tyres!)
Cheers
Chris
Just think how much power can be had with a good set of cams and some porting :D.  You can make the same power, using less boost, better response and less stress on the engine.
I couldnt justify spending $900 on a set of cams, $600 (or more) on porting where the offset can be had by screwing in another 1-2psi to the thing to attain the same result, and that was free
cams probably wouldnt have increased response much at all, and the engine wasnt stressed by any means.
There was talk of 30psi a number of times... just to see, but $$ said otherwise.
The main reason i didnt however because everyone said. cams cams cams after 250/260.
And i was sure on good advice that i could get pretty close to 300 as the 25 head is quite good stock
My RB26 im doing now is a different kettle of fish however
A concern if its a daily driver.
How will cams negatively affect fuel economy.
My fuel economy is pretty good - 450 to 500km driving normally.
If I put the foot down, I will only get 200 or so?
Does this sound right? - I/m not really thinking about cams now, it is a daily driver with a few drag meets now and then and maybe a few races on the circut for fun.
Cheers
Chris
Lower boost, higher airflow and more power are all about removing/reducing the restrictions. After all boost is simply a measure of restrictions, it is airflow that makes power. The usual restrictions are;
A. Exhaust, turbo back including dump and cat
B. Inlet, before the turbo. Pipework, undersized AFM, air filter
C. Inlet, from the turbo to the inlet valves. Pipework, intercooler, throttle body, plenum, inlet manifold, ports.
D. Turbine, the turbine itself can be a major restriction. It has to small enough to give good boost response and yet large enough not to be too big a restriction.
E. Engine, valve sizes (both inlet and exhaust), valve springs (too light and they will cause valve float), cams, cam timing (adj cam pulleys).
Some of these items are not a problem at your power level, a lot of the items are never a problem on RB's, the usual suspects are;
1. Tuning, how close is the tuning?
2. exhaust, turbo back
3. intercooler and pipework
4. cams
5. valve springs
6. ports, every RB cylinder head needs porting
What I do is to work my way down the list, checking on the dyno each item (eg; drop the exhaust in front of the cat and see how much power it is costing, remove the air filter etc). There is no magic, just thorough testing.
:D cheers :O
Edited by Sydneykid
4. cams
5. valve springs
:P cheers :)
Thanks Gary
The tuning is Excellent (RacePace Motorsport)
EXHAUST - well it is a fairly used, but new CAT, JASMA 3.5" system - might check again.
Intercooler, used but seems to be working fine (Apexi GT Spec, could do with upgraded pipes maybe?
CAMS - STD RB25DET
Valve Springs - I think these are std, but I will double check.
Head Porting - This was done properly, full rebuild with a excellent porting job
Plenum is STD
(Before Turbo/ECU/Mnifold/Inj/Coils (etc) mods were done the fully rebuilt engine made 213RWKW at 14psi using Apexi FMIC, SAFC 2, Bosch 044 fuel pump & surge tank etc.. BOOST cut was the restriction here,
I think if it was dynoed with the Power FC then, it would have kept going a fair bit more.
Cheers
Chris
Looks like my theories, on progression of modifications, are in line with Gary's (Sydneykid), but i am doing all of them at the same time :lol:
Gotta be happy with that! :D
The only concern may be my exhaust system, as i intend to make it even quiter (again). My first system only had a short "hotdog" and a straight through cannon muffler; bloody loud but bareable. My second/current system was changed to a long "hotdog" and a hi-flow muffler, deep on idle but pretty resonable while driving (alot quiter than previous). I am now going to remove the "hotdog" and replace it with a second hi-flow muffler. I have been told that i would only loose a maximum of 5-6rwkw from the original set-up, but am willing to sacrifice a little rwkw to hopefully sneak under the police radar :blink:.
Hi Chris;
just wondering how much lighter your flywheel is over standard, if at all...and how it effects drivability/performance..
i am in the process of changing my clutch and pondering if its worth getting a lightened flywheel, and how much lighter...
although at the moment i only have 200rwkws, i am aiming for around 260-280..
cheers
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
