Hi mate, My clutch set-up is very good. I never had a std clutch in my car so I can't really compare that much. The last clutch I had was something aftermarket but never found out what model.
The OS Giken Twin Plate & flywheel is very strong and should handle 300rwkw easily on the street. I won't be racing my car alot, so I don't need to worry..
The only thing that I have noticed is that the clutch grabs hard, and takes a bit getting use to. I stalled my car 3 times on the way home from Lilydale to Woori Yallock, when living there & I have used varying manual transmissions all my life. It only took about a week though before it seems like any other clutch.
Overall, I think that if you want a good reliable twin plate clutch, the OS Giken is a good choice, but it is worth checking out some others (in cars) if possible, to see the differences.
I hope this helps, as I am new to the Skyline Rebuilds my self.
Cheers
Chris.
  • Replies 48
I will definitely be going a lightened flywheel when this stocker chews out.
I found the nicest benifit of the lightened flywheel is how much easier it is to slap the next gear at high rpm. The stock weight flywheel that holds rev's up, I find I 'occasionally' miss the gear.
no idea, but it isnt stock, cant say i think of it as a disadvantage @ all.
i'll find out... this weekend if its got any markings on it when we change things over to my 26 :)
and yeah, the OS twin is nice and grabby hey Chris ;)
I'll have to check ur car out soon :)
No worries Ash, I havn't got that much to do to complete the car - Whiteline complete kit (from Sydneykid's group buy) a full respray (not including engine bay)
& I couldn't help myself the other day when I bought a GTR bootlid & adj. rear wing 400R Bar & grill (one peice), side skirts & a Trial rear bar (I couldn't find the 400R rear bar with spats)
No, Ben didn't rebuild my engine. He was too busy at the time I needed it done. I was a little uneasy getting it done somewhere else, but it all turned out Great. Ben was very happy with the engine build, he looked at my spec sheet and had a good listen and the tuning went well to. I got CaveHill Engines in Lilydale, they have built alot of Race engines and RB engines in the past. - Highly recommended
It took about 5 weeks to do (including OS Giken Twin plate clutch and flywheel), I supplied a few parts (GTR RODS, BOLTS, Clutch & flywheel, etc..)
Ben at RacePace did my Turbo/Manifold?Wastegate/PowerFC setup & I got the result I was after.
Cheers
Chris
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
