Hi Mate, My Full Engine Rebuild cost $6500.00. This Included all the good gear, & the block was O ringed etc... PM me if you want all the specs/parts.
The extras cost (Turbo/manifold/fuel/tuning) $$$, but I got some parts very cheap, cause I shpped around and didn't hurry.
Cheers
Chris
  • Replies 48
Another quality job. Good to see that the stock cam'd RB25 heads pumping great power without the need to spend $$$ on em  :)
But you will never know it's true potential, till you spend the $$$ on them :lol:
Just think how much power can be had with a good set of cams and some porting :huh:. You can make the same power, using less boost, better response and less stress on the engine.
around 10-12k in total?
Yeah around 12,
New Garrett GT30R - $1560.00 del from Sydney (I got this from a forum member, but won the bid on Ebay where it was alot cheaper than his asking price on SAU)
New HKS Lowmount Manifold - $900 del from Sydney.
Nismo 550cc Injectors - (Nengun) around $950 delivered
OS Giken Twin Plate $1800.00
Apexi PowerFC (Nengun) around $950.00 del
Splitfire Coil Pack - $560 - del -SAU Group Buy
Bosch 044 & surge tank setup in Boot - $1150approx Fitted.
HKS BOV $380.00 del from Japan Supplyer
$4000 spent at RacePace to install the Turbo/wastegate/Manifold/Injectors/tuning etc..
$400 - Setrab 19 row Oil Cooler & Perma-cool relocation Kit
$2270.00 Whiteline/Bilest/- Complete Suspension Package from Sydneykid's group buy.
$500 - GTR Bootlid & WING (included immaculate carbon fibre wing inserts)
$400 - Nismo 300km/hr speedo/ - dash full unit
Soon to spend more to finish car - Full Respray (except enginebay) in Polar White with a pearl through it.
Plus another $500.00 to install the suspension setup.
F**k This really adds up when someone aks you what you have spent.
Then It will be finished and Hopefully just spending on 5000km services (and Tyres!)
Cheers
Chris
Just think how much power can be had with a good set of cams and some porting :D.  You can make the same power, using less boost, better response and less stress on the engine.
I couldnt justify spending $900 on a set of cams, $600 (or more) on porting where the offset can be had by screwing in another 1-2psi to the thing to attain the same result, and that was free
cams probably wouldnt have increased response much at all, and the engine wasnt stressed by any means.
There was talk of 30psi a number of times... just to see, but $$ said otherwise.
The main reason i didnt however because everyone said. cams cams cams after 250/260.
And i was sure on good advice that i could get pretty close to 300 as the 25 head is quite good stock
My RB26 im doing now is a different kettle of fish however
A concern if its a daily driver.
How will cams negatively affect fuel economy.
My fuel economy is pretty good - 450 to 500km driving normally.
If I put the foot down, I will only get 200 or so?
Does this sound right? - I/m not really thinking about cams now, it is a daily driver with a few drag meets now and then and maybe a few races on the circut for fun.
Cheers
Chris
Lower boost, higher airflow and more power are all about removing/reducing the restrictions. After all boost is simply a measure of restrictions, it is airflow that makes power. The usual restrictions are;
A. Exhaust, turbo back including dump and cat
B. Inlet, before the turbo. Pipework, undersized AFM, air filter
C. Inlet, from the turbo to the inlet valves. Pipework, intercooler, throttle body, plenum, inlet manifold, ports.
D. Turbine, the turbine itself can be a major restriction. It has to small enough to give good boost response and yet large enough not to be too big a restriction.
E. Engine, valve sizes (both inlet and exhaust), valve springs (too light and they will cause valve float), cams, cam timing (adj cam pulleys).
Some of these items are not a problem at your power level, a lot of the items are never a problem on RB's, the usual suspects are;
1. Tuning, how close is the tuning?
2. exhaust, turbo back
3. intercooler and pipework
4. cams
5. valve springs
6. ports, every RB cylinder head needs porting
What I do is to work my way down the list, checking on the dyno each item (eg; drop the exhaust in front of the cat and see how much power it is costing, remove the air filter etc). There is no magic, just thorough testing.
:D cheers :O
Edited by Sydneykid
4. cams
5. valve springs
:P cheers :)
Thanks Gary
The tuning is Excellent (RacePace Motorsport)
EXHAUST - well it is a fairly used, but new CAT, JASMA 3.5" system - might check again.
Intercooler, used but seems to be working fine (Apexi GT Spec, could do with upgraded pipes maybe?
CAMS - STD RB25DET
Valve Springs - I think these are std, but I will double check.
Head Porting - This was done properly, full rebuild with a excellent porting job
Plenum is STD
(Before Turbo/ECU/Mnifold/Inj/Coils (etc) mods were done the fully rebuilt engine made 213RWKW at 14psi using Apexi FMIC, SAFC 2, Bosch 044 fuel pump & surge tank etc.. BOOST cut was the restriction here,
I think if it was dynoed with the Power FC then, it would have kept going a fair bit more.
Cheers
Chris
Looks like my theories, on progression of modifications, are in line with Gary's (Sydneykid), but i am doing all of them at the same time :lol:
Gotta be happy with that! :D
The only concern may be my exhaust system, as i intend to make it even quiter (again). My first system only had a short "hotdog" and a straight through cannon muffler; bloody loud but bareable. My second/current system was changed to a long "hotdog" and a hi-flow muffler, deep on idle but pretty resonable while driving (alot quiter than previous). I am now going to remove the "hotdog" and replace it with a second hi-flow muffler. I have been told that i would only loose a maximum of 5-6rwkw from the original set-up, but am willing to sacrifice a little rwkw to hopefully sneak under the police radar :blink:.
Hi Chris;
just wondering how much lighter your flywheel is over standard, if at all...and how it effects drivability/performance..
i am in the process of changing my clutch and pondering if its worth getting a lightened flywheel, and how much lighter...
although at the moment i only have 200rwkws, i am aiming for around 260-280..
cheers
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
