Yeah, rightio......
Got my new receiver dryer from nissan today and took it down to mac rad to get regassed with r134a (enviro junkies happy now???).
Anyway, aircon still didn't work cos the magnetic clutch was open circuit! damn it.
Got home and hammered a couple of washers into the compressor clutch, started her up and what do you know, the air con was working after 3 years or so of doing nothing.
It's going full time though cos of the washers. Just a stopgap until i work out how to get da clutch unit off and put a new one on.
Any ideas??
Cos paying $1200 or whatever the cost is for a new compressor don't go down too well for me.
The good news....... The Electro-magnetic clutch change will set you back a measely $110.00 :)
The bad news....... You'll have to get the gas back out of the system, pull the A/C compressor off and drive to Milperra :)
( There may be someone more local to you but this guy's the best I've found )
Call Jack on 9792-8265 or 0416-204-806 to make sure he'll be at the shop ( VERY busy man ) and then drive to 12/9 Ladbroke St. Milperra and in a couple of days it'll be all fixed.
F.Y.I. he can also overhaul your compressor AND change the clutch for $400 total ( from memory ) which is a whole lot better than $1,200 new from nissan.
Hope that helps :(
Cheers for the info.  It only got a bit of gas to check the system first anyway.  Just gotta pull the bastard out now!
Where is Milperra?  I'm in richmond.
Milperra is near Bankstown. Also, your A/C usually won't work unless you have full pressure in your system. So the compressor MIGHT not be your problem.
If you can afford to do it, get the compressor out, get it overhauled ( including the clutch ) and chuck it back in with a full re-gas and your A/C will be awesome. You might not think it's worth it now but summer is just around the corner :O
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
