SYNCHRO-MODE ATTESA E-TS (electronic-torque split) SYSTEM
(Electronic controlled torque split 4WD vehicles)
Depending on the conditions of the road, this system controls the drive force of the front and rear wheels providing an enhanced drive performance. The road and drive conditions are detected by various sensors and the front-rear wheel drive force will constantly change from 0:100 ratio (rear wheel drive) to 50:50 (4WD) depending on the drive conditions.
SYNCRO MODE
By increasing the drive force to the front wheels, the synchro mode provides enhanced acceleration from a standstill and turning performance even on icey roads and in severe conditions.
ADVICE:
When the syncro mode function in turned on, the following phenomenon will occur (These are no abnormalities)
-Tight cornering effect when driving at slow speed.
-Vibration when the engine is turned off with the steering wheel turned completely to the left or right.
SWITCH
OFF - 100% of the force will be on the rear wheels when taking off. When the rear wheels are slipping, transfer the drive force to the front wheels.
ON - The front and rear wheels will share 50% of the drive force each providing stronger take off stability.
Would people agree with this the yellow bit???? Maybe I should start driving with the torque split on more.
Well probably as the front will have the same power as the rears, so logic would dictate that a launch with 4 wheels driving would be better than a launch with 2 wheels driving and then having 4 kick in.
Still that means that you have 4 wheels driving all the time, which I dont know is a good or bad thing?
I have done some playing around with the snow button and she seems to get up and go a lot quicker with it on, dont realy notice anything different when just driving around normally, except for the HICAS light coming on when the snow button is pushed down.
I checked and no I dont have a HICAS unit on the back so I assume that the light is infact showning me that the snow button has been engaged.
Anyone else done any researching on it?
I drove with teh S mode on to uni and back today. For some reason i even notice more midrange in the car, compared to just normal driving. I find it also goes around roundabouts and uturns/courts a lot quicker with less understeer..
Snow mode doesnt adjust power, snow mode just doesnt use first gear.
Snow mode is on the transmission, syncronise is on the dash (S in middle of 4 wheels)
Oddly, Ians manual stagea didnt have teh S button feature, but Ska's manually converted one does...?? Odd ey?
You don't need a 'snow' button when you have the 'gear stick' one.. :)
With most autos (not sure if true with the stagea) all the snow button does is shift where the auto changes gears...
As for it locking in 4 wheel drive, you don't really need that, the stagea gets the power to the front very fast if the back wheels look like slipping, ie if I floor it at the lights in 1st , when I'm on a wet rd, the front torque (remember I have a gauge) cuts in pretty much at once anyway... It's also smart enough on dirt as well..
Ian
When i put mine in snow mode (on the trans), it just starts me in 2nd gear.
Like, i get bogged down launches and so forth.
The sync button is tottally different to snow, it makes certain its full time 50:50, and not variable as normal driving, therefore making it like its got a central transfer case which is permanently geared to run X split
Where is the button which we are all talking about?
Mine is on the left hand side of the steering wheel below the console, I'll take a couple of pics on the weekend :unsure:
All I know that when I hit the snow button it "seems" to take off faster and the HICAS light comes on.....?
So where is this sync button ?
Sync button is LHS of steering wheel, big boxy looking button & a light comes up on the dash, Snow mode is RHS of auto shifter (power, normal, snow), no light on dash but the button turns 'green'.
Edit: correct??
Also, in Snow mode my auto gets switched to 2nd gear, = slower takeoffs. If I want to be beaten at the traffic light grand prix I press snow mode! :lol:
Brendan
Edited by bwilkeson
I was driving on some loose gravel the other day playing around with Synchro off and on.
With it off the car still got sideways fairly easily, and spun the wheels when flooring it from a standstill.
With it on the car spun the wheels noticeably less when taking off and was not as easy to get sideways.
All of this was done with the trans in normal (i.e neither power or snow)
Ok, to clear this stuff up
The sync buton makes an orange/yellow light on the dash come one that looks like this
Snow button: Doesnt use first gear
Sync button: 50:50 split front/rear
My questions,
Why doesnt Ians manual stagea have the 50:50 split? Its more for traction etc, and sure the system is fast enough anyway, but...why?
"A/T Mode switch
Normal: Transmission will automatically change from power to economy mode as the conditions require (eg hill driving). When power is required the power light will appear on the dash.
Power: Gives the engine more power which is useful for hills, faster starts, etc. When the power mode is selected the power light will show on the dash.
Snow: For driving in snowy conditions. Place the select in the D position. The ability to start, drive and stop on slippery roads will be enhanced.
Note: This vehicle is a full-time 4wd.
Tight Cornering Effect: While driving with the Synchro mode in the ON position and the steering wheel is fully turned (to either side), the vehcile may brake suddenly. This is called the tight cornering effect and is the result of the difference in rotation speed between the front and rear wheels when the vehicle is turning. This is not a fault. The steering wheel will seem heavier to turn."
Synchro-mode: see first post
From the translated manual. I have no lights as such on the dash, but the switch itself lights up.(edited)
Q: Ian, is your car 4wd or 2wd?
Edited by bwilkeson
Surely you jest :) 4wd of course (It's a 25t RS FOUR S) ie http://english.auto.vl.ru/catalog/21830/
But remember I have a LSD, which might be helping me a lot - with previous cars I've noticed an enormous difference on dirt with or without a LSD..
I have a front torque gauge so can tell how much (and when) is going to the front. Even on loose dirt I don't have trouble with power going to the front instantly when needed, so don't feel any need for a switch to go 50:50… :) Which is probably why they didn't put one...
Sorry Ian, just asking, although I was hoping I wouldnt hit a nerve with the query. There seem to be so many variances within the same model of car....... :P
Well mines a manual convert with the 260 dash, which is prolly why I have that Sync switch.
I dunno if having a GTR diff makes any difference yet, I am yet to take it to a nice grassy patch for some "extra curricular" activites :)
Ska, what driveline parts have been changed in your car, doing the conversion myself right now, i will be swapping the diff with a NISMO item later when i can afford it...
Honetly I couldnt tell you excatly.....? PM Gary1 or contact Mercury Motorsports, details posted in your other thread.
found a pic of the button:
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
