I think you'd be best getting it serviced approximately every 5,000kms as everyone suggests..
I've only done just over 3,000kms in it - but want to get some decent oils and so forth into it before the summer comes along and get it checked over.
Yours would be worth checking that the timing belt has been changed - if I lived in castle hill I would possibly pay the full amount to get an excellant service done on it. or as everyone recommends Nathan..
On a car that's done 100,000kms without any thing for you to go on you probably want someone to check over it as there can be small things that cost you alot later..
Cheers
Cheers
Thats true...although there's this little plaque thing in japanese on the front of my engine which I'm guessing is the 100,000km service plaque which eased my mind a bit but I think that's a good suggestion.
Cheers
AF
Just my 2c for Grey Imports, aka Nathan. I have had my Cefiro thru the workshop a couple of times and all i can say is AWESOME!!!
Nathan is a honest bloke who will always give you the time of day!
An example is one Sat arvo, after he normally would of shut up shop my Ceffie had a issue. I called him up and was happy for me to take it down to him right then and there.....in his own time, that arvo he fixed the issue up!
Top bloke and would truely recommed him!
Ando
Cheers
AF
Actually I think you'll find its a sticker reminding you to change the belt at 100,000.
Best to change it and save an engine/
Well thought i'd give an update on the service..
Dropped my car in at Polmar yesterday morning at 8:30.. left it in Eli's hands to go over for the day while I was at work..
Got a call at about 3:00pm telling me everything was finished..
I'd asked for a Engine, Gearbox and Diff oil change.. He was kind enough not to change the Diff oil as he thought it was still fine (i didn't mind).. flushed and changed the Engine, Gearbox and Oil filter..
Overall car is running much better, oil pressure is just over 2 at idle whereas before it sat on 2.. must be the difference in the oil rating..
Cost me a bit over $140 in Labour and about $180 in parts + oils..
Goto say.. my gear box slides in smoother than a ...... in a .......
I LOVE IT!!..
anyways.. thought i'd give some feedback, appears that the car has been well looked after before I got it, no metal in the gearbox oil on the magnet and everything runs well.. so i'm a happy man
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
