Uas Standard Car Service
Links
 Share
I think you'd be best getting it serviced approximately every 5,000kms as everyone suggests..
I've only done just over 3,000kms in it - but want to get some decent oils and so forth into it before the summer comes along and get it checked over.
Yours would be worth checking that the timing belt has been changed - if I lived in castle hill I would possibly pay the full amount to get an excellant service done on it. or as everyone recommends Nathan..
On a car that's done 100,000kms without any thing for you to go on you probably want someone to check over it as there can be small things that cost you alot later..
Cheers
Cheers
Thats true...although there's this little plaque thing in japanese on the front of my engine which I'm guessing is the 100,000km service plaque which eased my mind a bit but I think that's a good suggestion.
Cheers
AF
Just my 2c for Grey Imports, aka Nathan. I have had my Cefiro thru the workshop a couple of times and all i can say is AWESOME!!!
Nathan is a honest bloke who will always give you the time of day!
An example is one Sat arvo, after he normally would of shut up shop my Ceffie had a issue. I called him up and was happy for me to take it down to him right then and there.....in his own time, that arvo he fixed the issue up!
Top bloke and would truely recommed him!
Ando
Cheers
AF
Actually I think you'll find its a sticker reminding you to change the belt at 100,000.
Best to change it and save an engine/
hmmm never tried UAS for a service......so I cant comment
but if your after an alternative try Pro Concept in west ryde.
9807 4488 ask for Josh......
He is very particular about his work and gaurantee one of the CLEANEST workshops around....
Thomas.
Well thought i'd give an update on the service..
Dropped my car in at Polmar yesterday morning at 8:30.. left it in Eli's hands to go over for the day while I was at work..
Got a call at about 3:00pm telling me everything was finished..
I'd asked for a Engine, Gearbox and Diff oil change.. He was kind enough not to change the Diff oil as he thought it was still fine (i didn't mind).. flushed and changed the Engine, Gearbox and Oil filter..
Overall car is running much better, oil pressure is just over 2 at idle whereas before it sat on 2.. must be the difference in the oil rating..
Cost me a bit over $140 in Labour and about $180 in parts + oils..
Goto say.. my gear box slides in smoother than a ...... in a .......
I LOVE IT!!..
anyways.. thought i'd give some feedback, appears that the car has been well looked after before I got it, no metal in the gearbox oil on the magnet and everything runs well.. so i'm a happy man
 Share
    • Another complicated thing is to run Z32 alloy hubs which have wheel speed sensors for ABS. You need different tie rod end, and you need new bearings on the upright etc. I did that as part of a major refresh when my front kingpin bearing flogged out., Alloy was a little lighter, runs a bigger bearing , gives a few extra mm in wheelbase as it moves the wheel forward in the arch (cant run crazy but can still get 8ish comfortably).   All in all glad I did it but was a head fark as tried it once and abandoned it the first time. sav man swung his spanners at it and got it working so using his guidance on GTR/Z32 tie rod ends etc and the required mismatch of parts was able to make it work.  Probably a 2k upgrade all said and done :(   I think the best bet is just look around your front wheel and see what you can pick up rotationally. You see old Escorts, E30s etc all get very creative with front uprights and the humble old angled alloy bracket.
    • Big claims here.  Any links up on the website ?
    • If your HP goal is reasonable and you are not drifting. Buy a new R34 box.  If the above is not true, buy a wrecked R33 box and put a gearset in it.  CD09 are not as strong as you think and the cost of / mess around of the conversion puts you in gearset territory.    Also the deal above is awesome,, get that
    • Just got back from a little hands-on with a G58 Baron....I was thinking about this... ..best I can figure it, that pinny was tail-ended ...I didn't really think about the wiring, because all that mattered was the tank and pump cradle (I think I mentioned the pump itself I couldn't vouch for)...which didn't matter, as you said you'd be replacing the pump anyway.... ...'for some reason'....and I imagine this is the panel shop's doing... they've replaced the cradle wiring with a metre of 7-core trailer loom, and attached the loom plug (from a different car) to that. The actual cable run from the top of the pump cradle, to fuel pump harness end in boot, is maybe 60cm in length...so I've no idea why they did this... ....the connector in the boot of the pinny, is not going to help you here...because in theory, it should still be present on your car. On top of that, because they've done what they did, we have no idea which colours of the trailer cabling, have been connected to what on the fuel pump cradle (pump +/- , shield, fuel guage/low-level senders)... ...this means, best approach is to remove the pump cradle, and re-work it now ...not later. That is, if you were going to replace the pump, do it, replace the soft lines at the same time...and sort the wiring out (replace that trailer cable with the wiring loom off your old cradle)...
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
