Mintie and a couple more of us went for a swim! We even had some hot scenery over near us! mmmmm hot.... scenery.... awhhhhhh
yeah.. plenty of scenery.. also plenty of good photos. managed to get my car in a number of them..
mmmm.. still thinking about that boosting we were doing through the old pac..
a newtattoo - think you were the one I got a water for.. whoevers that red car is that you were riding in looked nice sitting low..
Edited by Links
  • Replies 625
Posted Images
didi you get any good video??
yes indeed we got good video... until the point where that R32 GT-R was getting loose, and then boosted off... stans tyres werent up to the job of hauling the 'line around the corners uphill! :)
stan, i want a copy of that video! either digitise it at my place - or burn me a copy! :)
Anyway I have to say that I nearly didn't go on the cruise!
Everyone went up the F3 except for me and I didn't know who I was meant to follow.
I ended up going up through Hornsby/Asquith/Mt Colah on the Pac Hwy and I was hollering "anybody out there?!" on the CB all the way. Luckily somebody answered near the Berowra exit and I met up with you guys.
Thanks to menthu for hooking me up with the CB. Saved my arse today. Still, next time I need to get some mobile numbers just in case the CB is out of range. :)
siksII get a cb, we were trying to communicate :)
hey silver, wat did the coppa do u for?
Hey mate, i would barely use one so i have refused to buy one, a close friend of mine knows this so he bought two so he can force me to use it when we go cruising, he was not there this time = no cb for me! ehe
so maybe next time, although you could have screamed out the window at me :)
:) sorry silver..
CB came in handy.. next time we goto get everyone together before we leave and say "we are going up the freeway, turn off at berowra and we'll regroup there"..
was a bit hectic doing some good old.. should we go this way.. should we go that.. than having to cut through traffic.. always fun.. with mintie coming up the rear :)
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
