  • Replies 625
Posted Images
When did you blokes go through the old pac? A bloke got taken off his bike at the northern end (gosford) and wasnt in good shape so the road had to be blocked. Most bikers come off there because they often cut the corners and clip a car racing the other way, so take it easy on the blind corners :rolleyes:
Get your coils packs checked aswell as your sparkplugs.
k, will do
GTAHH.. yeah there were 2 motorbike accidents that i saw throughout the day on that road..... very sad.
Don't think this is causing the issuethat we are having, main reason we're driving popcorn makers is because of excess fuel (while running very rich) being dumped is igniting in the dump pipe when we back off the throttle from full boost..
cars aren't stuttering or suffering issues with ignition which is a normal indication of coil packs.. if it was a coil pack issue it would most likely be happening when it's wet or higher up in the rev range not 700rpm..
i get the same popcorn sort of noise, but only when ive revved it out a bit past 4k. A bit of excess fuel dribbles into the exhaust and ignites (i assume?)
Did the same thing when the car was stock (but more boost). Definitely not an issue with the coils, because it happens off boost.
Sounds like it could be a common thing in skylines and prob turbo's for that matter.. not helped when it's a hot day either.. as it was on Sunday.. had all the windows down and sunroof open.. was still bloody hot..
what time did people hang around Avoca till?? Stan - how's that video coming along.. I wanna see - make sure you leave some sounds in the background, always nice to hear a turbo spoolin..
Edited by Links
I have both problems...lol..
The only popping I ever get is when I push the car to near red-line and then let go of the accelerator - when the revs are coming back down, there is a TINY little 'pop' that goes off :D
It's so tiny I can't even be bothered worrying about it...
yeh i think most skylines get that though.. i also need a powerfc, but dont have the money for it. car runs a lil rough on high boost (11psi)
I'll take you for a ride next time stan and you can listen to my beast.. I'm over it now.. just makes me chuckle everytime.. my mate and i were just laughing about it the whole way up.. Your SAFC2 could be helping to counter the issue..
Edited by Links
Man let me get home first :D and Menthu_Rae and I will be looking at this video on Friday - trying to figure out how to lock it down so only WE (SAU Members) can access it :P
EDIT:
Hey Ed I sent it to you last night... haven't you got it yet?
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
