Can someone please explain (from a suitability point of view), the difference between using an 80mm diametre actuator and a 100mm diametre actuator?
The turbo in question is a HKS GT2835 Pro S (A/R 0.87) - internal wastegate.
I'm aiming to produce approx 275rwkw (@ 18-20psi) with supporting mods and possibly a set of Tomei Poncams on a RB25DET.
Nengun supply the turbo with either the 80mm or 100mm diametre actuator ( SEE HERE ), so I'd like to understand the difference between using either size actuator and also which one would be more suitable for my potential application.
Sorry for the dumbarse question - i've done a search and found plenty of info on wastegates etc, but nothing specifically to answer my question.
https://www.sau.com.au/forums/topic/89825-actuator-diametre-size/
I'd send the question to Nengun because i think it may actually be the size of the bellmouth on the turbo 3inch vs 4inch rather than the size of the actuator because typically the hks actuators are closer to 50mm diameter.
The size of the actuator would have little effect, particularly if it's an adjustable type like a HKS one.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
