Due to unfortunate circumstances I am forced to sell these turbo's. They were going to go on a stroked 2.0 to 2.4 but I have decided to get all the fruit so the engine is done and wont ever need a spec change for more power. Basically its a $10,000 Engine, that does not include accessories. I.e. Engine only! So, I have decided to sell these, which I had put aside for the engine (I wasnt sure which one would suit it better and was going to try both) I will now have to use the exsisting turbo on it (K26 KKK Sard kit) for the run in and base tune. At the end of the year or early next year I will then start making some turbo changes and revisions as needed. I need to sell these shortly (so no layby's) as the short engine is built and I need to order the rest of the head stuff (larger valves, Springs, Ti retainers, exhaust cam)
Item: HKS GT3037S 0.87 AR Exhaust (480ps @ 1 Bar)
Item Condition: Superb bar a couple of small, insignificant knicks on the compressor from not running a filter. (see pic's) Used for 9,000 Klm, been in storage for 6 months. There is no shaft play, thrust movement, oil leaks or cracks
Reason for Selling: As above
Price and Payment Conditions: $2400. Can ship nation wide for $38 via courier with tracking and insurance. Contact me for a definitive quote
Extra Info: Has EGT Sensor hole drilled and 90 deg trust alloy bend welded to the compressor outlet
Contact Details: [email protected]
Item: HKS GT3040 1.12 AR Exhaust (500ps @ 1 Bar)
Item Condition: Immaculate! This has done 5,000 klm on 12 psi on a 1J engine. There is no shaft play, thrust movement, oil leaks or cracks
Reason for Selling:
Price and Payment Conditions: $2600
Contact Details: As above
Serious parties email me for more pic's
Can supply braided oil line, oil drain, turbo inlet and outlet gaskets for
an additional $200 (will suit both turbo's)
Edited by amosite
https://www.sau.com.au/forums/topic/89834-hks-gt3040-and-hks-gt3037s/
Reason for Selling:
bought one of these off amosite last year with exact same specs........ ... just put the car together and getting it dyno'd on monday .. i'll let you know the results so people can get an idea of what is possible with this turbo on an RB25 ..
I thought I uploaded them already! I will upload some shortly (or email me if needed)
They wont fit directly to a stock manifold, but I have an adaptor that will fit with provision for an external wastegate for (I had this put aside for a rainy day) which I can do for $250
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
