meh, an owner of such expensive cars would be able to afford to get the car fully insured... just one phone call and no worrys........ you're with AAMI (sing it like the ads)
who gets pick axe insurance anyway????
i guess you could say "ah, it got keyed.....they used a really big one!!!!"
Had some tool park in my parking space which I rent yesterday. Had to fork out $25 for parking and was so pissed off. I went back to see if the tool was still there at the end of the day so I could throw some brake fluid and "improve" his paint job but alas.... they pissed off.
True lol.
If the person who damaged the car was smart, they'd of damaged the car enough to cost a bit, but not exceed the excess. Then come back and do it again and again when the car was repaired.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
    • A few more recent pics
