Hi ppls,
I've recently dropped a VG30DET turbo on my RB30DET to keep me happy until xmas.
I've just measured up the VG30DET and old S2 R32 RB20DET BB Turbo.
It appears the VG30DET and RB20DET S2 turbo's have an IDENTICAL compressor wheel.
Inducer - 46mm
Exducer - 63mm
The only difference between the two turbo's is the vg30's larger turbine and compressor cover.
The VG30DET turbo has smoothed out spool, increased bottom end off boost torque and made the car feel like a turbo car again, that being where the top end rushes, not dies off as the rb20det turbo did.
Hope you found it interesting, more so disappointing, I did. :)
Edited by Cubes
https://www.sau.com.au/forums/topic/89890-vg30det-bb-turbo-info/
Its not tuned yet so I am unsure.
I'm however expecting a gain of around 20-30rwkw (~200rwkw) with peak power extended close to 6000rpm, the rb20det turbo with its small turbine housing had power reaching its peak and flattening out at 4400rpm then nosing over after 4900rpm. It wasn't much fun.
I initially bought the VG30DET in anticipation of having it machined to suit a GT30R -12 CHRA with the .6 comp cover.
This would make around 280rwkw possibly 300rwkw.
There is apparently a -14 that is simply a GT30R -12 with a GT35R compressor wheel. This 'may' surge on the 2.5ltr, it should be fine on the 3ltr.
Having the 3ltr I'm going to jump in and give the xr6t turbo a shot as it should be all in by ~3800rpm (the same as a VG30 Highflow on a 2.5ltr) and making some nice boost 8-10psi by 3000rpm.
The 3ltrs really need a big turbine to make use of the DOHC head.
The XR6T turbo I think is a really bad match to the RB30ET SOHC.
They spool the same ~3800rpm then makes its peak power around 4200rpm, flattens out then noses over.
Edited by Cubes
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
