Recently ive been seeing some funny things, (ok ok, i know.. everydays its like that) but there are some stand outs.. and i thought to liven up this forum, id share them... If you have any funnies (from japan) please post em up, and lets have a laugh!
I'll start with this...
The super computer that'll get me over the magic 400kw mark.. or atleast help me fail my TOEIC Test..
https://www.sau.com.au/forums/topic/89893-jap-funnies/
We did this quite a while ago already http://www.skylinesaustralia.com/forums/in...9196&hl=Japlish but it's always good to see 'Japlish' and other corny stuff out of Japan.
On topic though rs73 noted why they only 'selectively' misspell wordsin English... well maybe my missus can answer that:
"I don't know..."
https://www.sau.com.au/forums/topic/89893-jap-funnies/#findComment-1621782
"I don't know..."
Wakarimasen :)
I saw a simple one at the train station the other night, but had me chuckling for a while, not sure why. I was starving so I went into the convenience store and saw some packed sandwiches which looked like they would do the job. Now there were 2 different packs by the same company, one with 3 sandwich halves and one with 4 halves. Aside from that physical difference, the smaller pack was apparently only "Delicious!" while the larger pack was clearly better being "Dericious!" :)
Then again maybe you had to be there... :D
https://www.sau.com.au/forums/topic/89893-jap-funnies/#findComment-1623959
Wakarimasen  :D
I saw a simple one at the train station the other night, but had me chuckling for a while, not sure why. I was starving so I went into the convenience store and saw some packed sandwiches which looked like they would do the job. Now there were 2 different packs by the same company, one with 3 sandwich halves and one with 4 halves. Aside from that physical difference, the smaller pack was apparently only "Delicious!" while the larger pack was clearly better being "Dericious!"  :D
Then again maybe you had to be there...  :P
You see, now according to a 998 scoring TOEIC J-nerd who heads the 'English Department' at Hiramatsu Co (who make those wrappers for sandwiches) 'Jyaponeeze peepr can understand DERICIOUS... I know it's wrong but if we spell it the right way, only a limited amount of people can 'get it'... most will think it's some other inconsequential word...'
Edited by Rezz
https://www.sau.com.au/forums/topic/89893-jap-funnies/#findComment-1624648
Im Not sick of it.
Thought I saw Rezz the other day as a white guy in a maroon Skyline whized past up route 171.
But obviously not. He must have been out of the country by then.
Lets try some pics.
Edited by Bart Japan
https://www.sau.com.au/forums/topic/89893-jap-funnies/#findComment-1633237
Haha... no def wasn't me. That wine red Skyline is now on a ship to AU.
https://www.sau.com.au/forums/topic/89893-jap-funnies/#findComment-1634667
So anyone still in the area between Osaka and Kobe who can meet up for drinks some time. Getting a little twitchy after some friends left for other countries. Theres only so much sake you can drink while watching Chambara befoer you need to have a drink with real people.
https://www.sau.com.au/forums/topic/89893-jap-funnies/#findComment-1639627
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
