Guys,
This is the spec of my engine going into my R32 GTR will this make 350rwkw
RB26 Head
Rb30 Bottom End
Prepped Factory Rods
ARP Rod Bolts
CP Forged Pistons
O-Ringed
Balanced
600cc Nismo Injectors
Nismo Fuel Reglator
Apexi Power FC
Q45 AFM
XTR T60 Turbo
XTR 55mm Wastgate
6BOOST Manifold
Will this engine need cams to make the KW i want?
https://www.sau.com.au/forums/topic/89950-will-this-make-350rwkw/
Guys,
1. RB26 Head
2. Rb30 Bottom End
3. Prepped Factory Rods
4. ARP Rod Bolts
5. CP Forged Pistons
6. O-Ringed
7. Balanced
8. 600cc Nismo Injectors
9. Nismo Fuel Reglator
10 .Apexi Power FC
11. Q45 AFM
12. XTR T60 Turbo
13 XTR 55mm Wastgate
14. 6BOOST Manifold
15. Will this engine need cams to make the KW i want?
One by one;
1. Yes
2. Yes
3. No
4. Yes
5. Yes
6. Yes, but what head gasket?
7. Yes
8. Yes
9. Yes, but not necessary though, what fuel pump?
10. Yes, but it will need to be tuned by someone who knows what they are doing.
11. Yes
12. Yes, very responsive
13. Yes, but it depends on the boost level
14. No idea, never heard of them
15. Would do better with some upgraded cams, get the boost down a little too
What inlet/plenum are you using? If standard RB26DETT then that will be OK.
Would do better with a ported cylinder head, help get the boost down a little at the same or higher airflow. Little bit more power and a lot less boost, that's the target, helps the engine live a little longer
Personally I think you have a conrod power limiter, I have not seen standard RB30 rods live in a DOHC environment (higher rpm and faster acceleration than SOHC) much over 500 bhp (300 rwkw).
Hope that was of some help
:D cheers :(
6Boost has been churning out steam pipe manifolds, not too bad quality wise. Why would you need to upgrade rods, I mean with RB26 rods being proven to reliably go over 400awkw and the longer rod/stroke ratio how could the RB30 rods not be up to par?
60mm turbo =~ 60lbs airflow, roughly 600hp/450kw @ flywheel, so just under 400rwkw in geek hypothetical speech.
I know, I know...........but (there is always a but)
We are up to around 30 X RB30DET's now and the ones that have standard rods and stayed below 475 bhp, 1.1 bar and 7,500 rpm have not had a problem. The ones that have exceeded 475bhp and/or 1.1 bar and/or 7,500 rpm have all had problems. The most common being big end bearings, the big end journals are no longer round and the little ends bearings are oval on the compression load.
Maybe if you could make 600 bhp at 1.1 bar without reving them over 7,500 rpm it would be OK.
:D cheers :(
SykneyKid answers
R33 GTR Fuel Pump with a direct 12V supply from Battery
I can get a set of H Beam rods from Spool Up imports and a set of HKS 272 cams would this be better
The tuner is good at what he does
Edited by GTR_Junkie
:) cheers :)
Have you built any with aftermarket rods? and what rpm do you take them to?
Ok, what about if i throw a set of Spool Up RB30 Rods and some HKS 272 cams?
Are they rods from Brad (Spool Imports)? If so, they are OK.
The HKS 272 cams might be a little big, the T60 is going to build boost a bit early, with 3 litres of exhaust, for them. The Jun 264's with high lift would be my choice.
:) cheers :)
if you dont want to have to machine the head and replace valve spring, cam retaining studs and lifters(depending on lift) the TOMEI 260 deg 9.15mm PONCAMS are direct bolt in fit and i got two rb26 making 400rwkw+ on them with great responce with small twin turbos.
i think the combo will make the power you want with cams you may struggle without them, i would recommend adjustable cam wheels if you are willing to spend the time tuning them (well worth it on rb26 and especially rb26/30).
and i would go the aftermarket rods as SK stated
other ideas you might want to concider
tomei oil gallery restrictor ($6)
N1 oil pump or better
N1 water pump
metal gasket instead of o-ringing the block
low temp thermostat (if your going to work it hard for long periods)
ok then hahaha what about without a billet crank girdle, what rpm have you found safe with aftermarket rods
In a circuit racing environment I have found no reason to go over 8,000 rpm. They make plenty of power, that's why we use 3.1 litres, so we don't have to rev the beegeesus out of them. It's the same airflow as an RB26 at 9,600 rpm, assuming equal efficiency, and that isn't going to happen.
:) cheers :)
Guys,
RB26 Head
Rb30 Bottom End
ARP Rod Bolts
CP Forged Pistons
O-Ringed
Balanced
Nismo Fuel Reglator
Apexi Power FC
Q45 AFM
XTR T60 Turbo
XTR 55mm Wastgate
6BOOST Manifold
probably add some head studs in and some good bearings......... i dont reackon you need cams, what is the intended use for your car? maybe this will govern the need for cams.....your coils might cry for help when you start making more power then 350rwkw :D
I'd say a definate need for cams, as already stated.
The RB26 takes extremely well to a mild set, and thats all you'll need for 350rwkw.
Coils could be a problem indeed, depends on thier condition
Ok, hows this then
RB26 Head
HKS 272 Cams (from Fatz)
HKS Cam Gears
RB30 Bottom End
O-Ringed with Nissan Head Gasket
CP Forged Pistons
Spool Up H-Beam Rods
Nissan Bearings
Nismo 600CC Injectors
R33 GTR Fuel Pump (direct 12V supply from battery)
Nismo Fuel Reg
XTR T60 Turbo
XTR 55mm Wastegate
6BOOST Manifold
Apexi Power FC
Q45 AFM
Twin Plate Clutch
What do you guys think?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
