Ok, well as everyone would know, i am going for the manual conversion.
I have decided to go with the r33 GTR gearbox, as Stagezilla, as its supposed to be the correct length to not require a new driveshaft
Sooo, one thing i am doing differently to Stagezilla is that i am going for just a GTST master. At the same time as buying the master, i bought a GTST slave, GTST pedal set (clutch/brake/accel).
Now, i know that the r33 gtst is a PUSH style clutch system, but someone explain to me what i am talking about below.
First, here a picture of a R33 GTR slave on yahoo JP.
And the clutch setup with mock attachment to master
Now, here is what i am experiancing. With this clutch/master (which is pretty generic inc same as GTR) when the clutch is pressed, pressure is built up in the master, therefore causing pressure in the line, and eventually makes the piston at the slave PUSH out. Now, considering i dont know the main difference between PUSH/PULL, the only way that i can see that it could "pull"(as a gtr should/need to go for gearbox) the clutch would be
a) for the little rod to be welded to the piston inside, and then the fluid from the lines to enter the "forward" chamber to "push" the piston back, causing it to pull the clutch
B) the pivot point on the clutch to be BELOW where the master attaches to the clutch, therefore making the master "pull" the pressure into it, casuing the welded little rod to be pulled back. Now, i reckon there would be a lot of strain if it was actually pulling...
soooo... option c is that it just mounts on the other side of the clutch, meaning all i would need is new lines between the master and the slave, which i wanted to get from Maltech anyway....
Sooo, anyone got any ideas...
PS, if you cant tell, im new to this PUSH/PULL thing
At the moment, the only thing holding me going ahead is waiting on my gearbox to arrive, powerFC and also sorting out this push/pull thing, otherwise, ill be finished within 1-2 months.
Edited by AlexCim
https://www.sau.com.au/forums/topic/89967-clutch-system-in-a-manual/
Give Mercury Motorsports a ring, they should be able to help you out as they did most of the work on my stagea manual convert before I purchased it. Ask for Trent on 1300 558 650.
But the box that went into mine was out of a r32 gtr, so it's prolly all different, but they still should be able to help you out.
nah its easy from a slave cylinder point of view the only difference between push and pull is the side of the clutch fork that at pushes on....ie in one it faces forward and the other it points backwards
Well we fitted a 33 GTR box and had to reverse the slave cylinder to fit it properly.
But the 33 GTR box actually had the points to mount the slave cylinder backwards already cast into the housing, all we had to do was tap holes for the bolts.
If you have a pic of the housing I can point it out for you
i will, just wanted to be sure that i can mount the slave that i have. This is because on Nengun, they differentiate between the PULL and PUSH slaves, so i thought there could be something different.
After i posted, i thought about it a bit more, and i should be sweet :D
One step closer
Ill be getting an ATESSA controller soon too :D
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
