Any sort of front lip would be great. They appear to always get ripped off. Even fibre glass could be worth it. Are there any other options available?
I don't think fibreglass would go too good. Especially since they sit so low..
I think carbon fibre of Kevlar would be the go.
Greg
whats sort of cash would a cf lower lip go for?  If not outrageous I could be keen to get involved...
I'd imagine around the $200 mark. Which doesn't seem to be too bad by looking at these other prices. That is just a guess.
The only problem is that we would need to find an un-damaged front lip. That would be hard.
Greg
If we can get some made up for $200 or near that mark I'd def be keen and Im sure theres plenty of others with 32 GTR's with lips that need replacing. Surely there's a way to make it happen.....There would have to be someone around with a near new lip that can be borrowed?
Think it's a top idea if there's enough interest....
Is there anyone with the skills to get this made for cheapish? If so maybs we could get some interest in the Group buy section if we can put in an order for 10 of them???
If it makes you feel better the R33 GTR Front lip is about $1000-1200 from nissan, yep just for the front lower lip.
I wouldn't put fibreglass down there, not going to last long.
WOW!! How can they justify that price....
I wouldn't put fibreglass down there either!! Break in no time at all..
Greg
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
