Hiya,
I am looking into getting a FMIC for my R33 .... My car is stock barring full exhaust and air pod. I want to get the largest intercooler possible without going past the point of sacrificing performance....
I am looking at the two differnet types of HKS coolers.... One is 600x300x65 and the other is 600x300x100 ....
Can I run the larger of the two coolers without making my car more sluggish ( bearing in mind my next step is an AVC-R with boost increase ) or should I settle for the smaller of the two??
I don't want to have to swap if out later on because its not doing a good enough job but I also am not chasing a huge amount of horsepower...
Advice/Opinions welcome???
https://www.sau.com.au/forums/topic/9000-intercoolers-how-big-is-too-big/
I've got a 700x300x76 and found no increase in lag from a stock one.
Saying that, I think a 100mm thick core is a bit of an overkill.
60mm to 100mm thick core is a increase of 40% in volume (is that right ?? )
Go with the 60mm and save your $$$ for the AVC-R.
J
I've got a custom 700X350X75 and you can feel its adds a little lag on the standard boost. All you need to do is up the boost and you should be fine.
I only got this FMIC as it was selling cheap and I knew it had a good core, otherwise I would have gotten something a little smaller.
Best thing is to have a power goal and have a plan to get the right parts.
Just my 2 cents....
hahah at BK last Saturday with the Westside boys there was a commonwhore that had a truck intercooler. This thing was the biggest intercooler ive ever seen on my life. You could disconnect it while at the beach and use it as a surf board it was just massive.
He seemed to be getting quite abit of attention, i dont know if it was coz people thought it was fully sic or they just thought he was a knob hah.
I have no idea what size mine is but i know its large enuff (and not aligned in the middle properly arggh)
stock turbo?
Going circuit racing regularly?
If the answers are 'yes' and 'no' save your coin for something else, the stock cooler is fine.
If you must have a cooler for no other reason than everyone else has one, then get a small one that flows very slightly more than your peak power goal, with some efficiency.
If you want accelleration there are other things you can do.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
