hey all, just wondering which brand (either Trust or HKS) ppl think is better for a bolt on turbo... eg. GT2530 vs TD-05 and more importantly WHY!  ive heard that trust turbos are not water cooled, is there any truth to this??
Thats true with most of the trust turbo's, also HKS turbo's are modified garret turbo's and they are ball bearing which should help improve spoolup, and they can be rebult with carret internals, that said both trust and hks have excellent reputations so it's up to personal choice.
Td05 is only oil-cooled,
I wouldnt waste your money on a td05 if your going to buy anything i would do td06-20g with 8 or 10cm rear housing
Are we talking HKS or garrett as althou they are pretty similar i rate hks turbo higher than the plan garrett one.
heres a chart to find you an idea of Hp V's Turbo
trust turbos are oil cooled/plain bearing and based on mitsubishi items...
hks turbos are water&oil cooled/ball bearing and based on garret items...
it would have to be said that hks turbos are much better
not all hks turbo are water & oil cooled, for example the HKS t04e
when i said the GT2530 i was more thinking the HKS version.  from what i've heard theyre definately the way to go over the Garret one.  whats the difference between the two?
if you can find a td05 it should be pretty cheap, i almost bought one a few months back, the thing sold for about $600-$700 i think. compare to the HKS gt2530 which is about $1000-$1500
nothing wrong with plan bearing/oil cooled only turbos :P
Does anyone know where I can get my hands onto a Garrett or HKS bolt-on turbo for a RB25DET between now (Thrus, 6t Oct) to Monday (10-Oct) for around the $1,000 - $1,500 mark?
The workshop trying to source a turbo for me cant get onto any turbo's due to them all being sold out right now as we recently just had Jamboree here in QLD.
I'm pretty much after one really URGENTLY!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
