Hi Guys,
Contemplating doing my timing on my '96 S2 R33 GTST. I've sourced the idler and tensioner bearings however is in the process of getting the timing belt and water pump.
The question is....
Where can I get the STANDARD, Not N1, water pump from (one that would suit the RB25DET not the VL RB30)? Would Nissan be my best bet? However, if the N1 water pump is my only option, then where can I get that from?
Lastly, would I be better off getting the GATES branded timing belt or would the genuine Nissan would be better?
Any help would be great. Thank you.
Steve
https://www.sau.com.au/forums/topic/90040-where-can-i-get-a-water-pump-from/
A standard or N1 waterpump can be purchased from nissan ( not a big diffenerence in $'s from memory ). If you do track work or drive hard, go the N1 pump otherwise standard dhould be fine.
Take your VIN / Chassis NO. with you to get the correct pump.
From what I've heard about timing belts, go genuine nissan unless you're pushing out big power. I believe the "Gates" ones are more noisey and the blue coating falls off.
Hope that helps.
i paid about 150 for the standard r33 pump from nissan, considered the N1 pump at the time was about the same price, the N1 flows less at lower revs than normal pump so dont buy it unless u go to the track all the time or u risk overheating in normal conditions.
VL pump fits too u can get non genuine ones from places like auto1 for around $80
Edited by siksII
Hi,
I've heard that the VL pump doesnt have a screw hole where the standard nissan one does.... and this in the long run will allow leakage... thats why i want to get the standard 33 pump... and i dont take my car on track or anything plus live in the tropics so i want one that will cool the car when in low revs... thanks guys
Hi,
thank you... I'll give nissan a go..
Lastly, why do nissan need the VIN/Chasis number to get a pump??
Also anyone know the price of a water pump??
If you are getting a stock nissan pump, the VIN Chassis number will ensure that you get the correct one for your car. There actually are differences between many of the pumps. A HR31 RB20DET water pump is slightly different to a HCR32 RB20DET water pump and so on. The differences are subtle but noticeable. My mate recently replaced his HR31 ( red top RB20DET ) waterpump with a N1 BNR32 ( RB26DETT ) one and the physical impeller difference was huge ! As a result, his engine temp on the track stays the same now, lap after lap. Better engine temp with street driving too.
I replaced my w/pump with the correct one for my car when I rebuilt my engine. The temp gauge never reached half way before the engine rebuild and still doesn't. :D
I changed my pump over 12 months ago with a N1 pump. Price difference wasnt much, but N1 was cheaper than a standard (then), so I got that. I priced them just a few weeks ago @ time of writing this and the price has sky-rocketed to over $300 for a N1 pump from Nissan.
I wouldn't put a VL/R31 rb30 Skyline pump on as the impellors are much smaller than a standard rb25 pump. (Im in the trade and compared all options.)
***A WORD OF WARNING IF CONSIDERING FITTING A N1 PUMP***
If you fit a N1 pump to a GTS-t (mine is a R33) you must fill in the smallest bolt hole which takes the smallest bolt when fitting, which is directly above the impellor, with Devcon (part # S-5), or something similar so that only the bolt will fit through it.
ie: on a N1 pump, there is an elongated bolt hole where the standard pump has a round bolt hole. This hole must be (almost) filled to prevent coolant leaking out. YOU CANT FILL IT WITH SILASTIC OR OTHER GASKET GOO as it will break down over time and eventually leak, and therefore you will have to pull it all apart again and do it properly.
I wasnt told this when purchasing so hence I had to do it twice! :-(
Apparently this hole is used on GTR's.
Just some friendly advice.
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
    • That's just a gauge, with a certain amount of electronic damping, and no-one cares if it is timely-accurate. I'd hesitate to use it for an ECU MAP input without knowing that it was a nice signal. Responsive but smooth. Not laggy. Not lumpy.
    • Took the dirty BMW to an actual drag meet so I could do a legit full pass on a sticky enough track and had a quiet goal to try and beat my PB in the old R33 GTS25t The time to beat:  R33 on stock RB25, Internal gate GT3076R on stock manifold tuned to about 17psi on BP98 and running on drag tyres: F20 M135i with intake, dump pipe and MHD OTS Stage 1 tune on street tyres - didn't even drop the tyre pressure: Kinda similar, and kinda way different
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
