  • Replies 244
Posted Images
ok, those guys responded with this -
Thank you for your email regarding FC Datalogit.
BMS can offer FC Datalogit for the discounted price of $450 including serial cable connect for up to 10 units, or $425 for between 11-15 units.
For these units, BMS will ship to you free of charge.
FC Datalogit is currently out of stock, we will be restocked within three weeks.
so thats no frieght!
We need 11 guys.
Keep registering your interest!
Edited by The Mafia
when is this Group buy starting? so its 425 if SAU order 11 units? is that to suit any engine or just RB25?
does fc datalogit come with instructions for what does what?
Only things i know is rev limit,ign and inj map lol.
Updated List guys -
1. The Mafia
2. Beer Baron
3. Stolly
4. Snowman
5. Bl4cK32
6. yogi000
7. Ryosuke Takahashi ??
For those that want a look at the software, click this link, and you can actually click on the tabs etc to bring up that page of settings. Some very interesting setting in there.
http://www.fc-datalogit.co.nz/map-rx7-fcedit.html
Here are the features from Bl4cK32's post -
Ok, for tuning purposes the hand controller does basically the same as the datalogit. BUT there are a hell of a lot more fetures which imho make it worth the little extra...do a search and you may be suprised what you can do with it  from SK:
OK, but only the ones that you can't access via the Commander
Inlet air temp fuel map
Water temp fuel map
RPM acceleration fuel map
Cranking Injector dwell map
Water temp versus boost fuel correction
Inlet air temp versus boost fuel correction
RPM Load Point table
AFM load point table
AFM voltage table
Ignition versus water temp correction
Ignition versus inlet air temp correction
Ignition dwell versus RPM correction
Ignition versus battery voltage correction
Ignition versus boost correction
Individual injector trim
Injector lag versus battery voltage correction
Via the Datalogit there is also;
Antilag via injection
Antilag via ignition
Intercooler spray
Basically anything that you want to turn on or off
Then there is the logging
Every standard sensor is logged
Plus 4 others (eg; lambda, brake temperature, suspension travel etc etc)
as well as :
All of which are important once you reach the limitations of the stock afm/load point base map setup.
Swapping to a Z32 or VH41/Q45 AFM does zilch in its own.
Software is required.
There's also the A/C and non a/c overheat fan temp switch.
Edited by The Mafia
So there would be instructions about what means what such as mS,injector overlap etc.
Ive had a quick browse thought the datalogit software to suit rb25det.
I know the horizontal axis is rpm but whats the vertical axis?
The $425 is the single engine version. The multi engine version is more like $2K I believe.
The manual is ok, but is still a bit vague. You do get membership into the user forum where there is lots more info and you can post questions etc.
I'll give you guys a review once we use it to tune the car. So far been only fault finding to get to the tune stage.
Yep let us know man,It'll be great to be able to "fine tune" your own engine :(
Vertical axis is Load
People, this isnt a fault finding software. Its just the laptop software to enable you to tune your car via a full screen showing the 20x20 grid instead of the 5x5 on the hand controller.
It wont help you do magic things with your car "ie diagnose HICAS" - are you serious? - its a tuning device, and should only be used by a professional tuner....not backyard tuners wanting to play with their tune and kill their car....
I'm thinking of getting it so my tuner can tune my car better, and to do some dataloging for trackdays. How good is the dataloging function?
And is does anyone know for sure about the multi engine vs singe engine software. Just that I got 1 yes and 1 no.
Thanks
"It wont help you do magic things with your car "ie diagnose HICAS" - are you serious?"
Gee - sorry - yes I was serious. There is a whole lot of extra things you can access with the datalogit so it seems (like logging suspension travel I think someone said). The standard ECU has a diagnosis function so I thought the PFC may have one somewhere hidden.
Ok. Sorry if i sounded a bit harsh there. Maybe you should learn a bit more about your car before investing in some software and a cble to tune it with.
Suspension btw is no where even remotely connected to the cars ECU, or any ECU. Yes, there are 3 diagnostic modes the car has. 1 for the ecu itself, one for Hicas (has its own ecu) and the aircon has its own diagnostic mode.
