  • 3 weeks later...
  • Replies 244
Posted Images
one a side note a member who purchased a datalogit on the 11th of novembner 2005 recieved his datalogit invite to the user groups today so they are still activing and looks like the datalogit guys may be playing catch up. so there is light at the end of the tunnel
in summary
adjust rb25 variable cam timing rev setting (when it turns off)
save / reload tune data
advanced log all sensors and MONITOR items
advanced log external inputs (wideband 02)
supports antilag, boost scramble
mine has already paid for itself by allowing me to save / reload my tune a few times, log all sensors and support wideband tuning
besides letting you graph the knock levels, and being able to save your config, is there anything else the datalogit lets you do that is useful ?
Page 2 :unsure: of this thread i wrote:
Ok, for tuning purposes the hand controller does basically the same as the datalogit. BUT there are a hell of a lot more fetures which imho make it worth the little extra...do a search and you may be suprised what you can do with it :D from SK:
OK, but only the ones that you can't access via the Commander
Inlet air temp fuel map
Water temp fuel map
RPM acceleration fuel map
Cranking Injector dwell map
Water temp versus boost fuel correction
Inlet air temp versus boost fuel correction
RPM Load Point table
AFM load point table
AFM voltage table
Ignition versus water temp correction
Ignition versus inlet air temp correction
Ignition dwell versus RPM correction
Ignition versus battery voltage correction
Ignition versus boost correction
Individual injector trim
Injector lag versus battery voltage correction
Via the Datalogit there is also;
Antilag via injection
Antilag via ignition
Intercooler spray
Basically anything that you want to turn on or off
Then there is the logging
Every standard sensor is logged
Plus 4 others (eg; lambda, brake temperature, suspension travel etc etc)
as well as :
All of which are important once you reach the limitations of the stock afm/load point base map setup.
Swapping to a Z32 or VH41/Q45 AFM does zilch in its own.
Software is required.
There's also the A/C and non a/c overheat fan temp switch.
heaps. As well as for datalogging, i can hook up an afr meter and do logging on the street with AFR values, so i can do my own light throttle tuning to get better fuel economy.
I only have to pay $100 for a WOT tune, then take it home and fine tune myself (which is about another $200 on the dyno)
my contact reports that the latest version is 1.120 for RB25 which I now have (pm me if you want it) and unfortunately the latest version of the manual (if any) are not in the user groups so we can't get access to the latest manual.
Also to note there are lots of posts about anitlag not working for lots of people and little to no help or comments from the datalogit team on how to make it work either
My invite to join the user group arrived this morning. Very happy.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
    • You just say that the premium increase seems particularly excessive (no pun intended) and that the value decrease seems unwarranted. You say that it's not 2005 any more, and that these days Skylines are generally owned and insured only by those that have demonstrated an ability to keep them in one piece across decades, and are therefore not the horrible risk that used to be assumed. etc.
    • Have a look at JS Performance Garage, just did a bit of work on a 32 GTR.
