  • Replies 244
Posted Images
  • 3 months later...
latest software has been released for those interested.
I've uploaded the first (beta) release of universal FC-Edit
software. Functionality should be the same as the seperate FC-Edit
versions. All FC-Box types will work with the software - but if the
box type (A or B) does not match the Power-FC, then you may
get "Interface not responding."
Most of the work was behind the scenes, but there's also a couple of
minor additions:
- Airflow table has a tracer option, (right click to access) which
should allow easier tuning of the airflow curve.
- Drag and drop .dat files onto FC-Edit.
- Com port menu only shows available ports
For now I have disabled the Compare feature, due to the
complications of comparing different Power-FC versions.
Of course I have thoroughly tested on my RX7 Power-FC, but now I
need your help testing on other Power-FC's. Of course please be
advised that this is Beta software. There may be bugs. If you are
not comfortable with this possibility - then do not use it, wait a
while until it is officially released.
Once testing and bug fixs are done - then I can work on adding new
features. So if you do want new features - help me out by giving it
a try, and report any problems to me.
Thanks in advance
Steve
FC-Datalogit
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
