  • Replies 244
Posted Images
ok, those guys responded with this -
Thank you for your email regarding FC Datalogit.
BMS can offer FC Datalogit for the discounted price of $450 including serial cable connect for up to 10 units, or $425 for between 11-15 units.
For these units, BMS will ship to you free of charge.
FC Datalogit is currently out of stock, we will be restocked within three weeks.
so thats no frieght!
We need 11 guys.
Keep registering your interest!
Edited by The Mafia
when is this Group buy starting? so its 425 if SAU order 11 units? is that to suit any engine or just RB25?
does fc datalogit come with instructions for what does what?
Only things i know is rev limit,ign and inj map lol.
Updated List guys -
1. The Mafia
2. Beer Baron
3. Stolly
4. Snowman
5. Bl4cK32
6. yogi000
7. Ryosuke Takahashi ??
For those that want a look at the software, click this link, and you can actually click on the tabs etc to bring up that page of settings. Some very interesting setting in there.
http://www.fc-datalogit.co.nz/map-rx7-fcedit.html
Here are the features from Bl4cK32's post -
Ok, for tuning purposes the hand controller does basically the same as the datalogit. BUT there are a hell of a lot more fetures which imho make it worth the little extra...do a search and you may be suprised what you can do with it  from SK:
OK, but only the ones that you can't access via the Commander
Inlet air temp fuel map
Water temp fuel map
RPM acceleration fuel map
Cranking Injector dwell map
Water temp versus boost fuel correction
Inlet air temp versus boost fuel correction
RPM Load Point table
AFM load point table
AFM voltage table
Ignition versus water temp correction
Ignition versus inlet air temp correction
Ignition dwell versus RPM correction
Ignition versus battery voltage correction
Ignition versus boost correction
Individual injector trim
Injector lag versus battery voltage correction
Via the Datalogit there is also;
Antilag via injection
Antilag via ignition
Intercooler spray
Basically anything that you want to turn on or off
Then there is the logging
Every standard sensor is logged
Plus 4 others (eg; lambda, brake temperature, suspension travel etc etc)
as well as :
All of which are important once you reach the limitations of the stock afm/load point base map setup.
Swapping to a Z32 or VH41/Q45 AFM does zilch in its own.
Software is required.
There's also the A/C and non a/c overheat fan temp switch.
Edited by The Mafia
So there would be instructions about what means what such as mS,injector overlap etc.
Ive had a quick browse thought the datalogit software to suit rb25det.
I know the horizontal axis is rpm but whats the vertical axis?
The $425 is the single engine version. The multi engine version is more like $2K I believe.
The manual is ok, but is still a bit vague. You do get membership into the user forum where there is lots more info and you can post questions etc.
I'll give you guys a review once we use it to tune the car. So far been only fault finding to get to the tune stage.
Yep let us know man,It'll be great to be able to "fine tune" your own engine :(
Vertical axis is Load
People, this isnt a fault finding software. Its just the laptop software to enable you to tune your car via a full screen showing the 20x20 grid instead of the 5x5 on the hand controller.
It wont help you do magic things with your car "ie diagnose HICAS" - are you serious? - its a tuning device, and should only be used by a professional tuner....not backyard tuners wanting to play with their tune and kill their car....
I'm thinking of getting it so my tuner can tune my car better, and to do some dataloging for trackdays. How good is the dataloging function?
And is does anyone know for sure about the multi engine vs singe engine software. Just that I got 1 yes and 1 no.
Thanks
"It wont help you do magic things with your car "ie diagnose HICAS" - are you serious?"
Gee - sorry - yes I was serious. There is a whole lot of extra things you can access with the datalogit so it seems (like logging suspension travel I think someone said). The standard ECU has a diagnosis function so I thought the PFC may have one somewhere hidden.
Ok. Sorry if i sounded a bit harsh there. Maybe you should learn a bit more about your car before investing in some software and a cble to tune it with.
Suspension btw is no where even remotely connected to the cars ECU, or any ECU. Yes, there are 3 diagnostic modes the car has. 1 for the ecu itself, one for Hicas (has its own ecu) and the aircon has its own diagnostic mode.
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
