Toyota Supra
Munna
 Share
I know the twin turbo 3ltr sequential twin turbo supra has a lot of potential. But I was just wondering if anyone knows what rwkw are achievable with the following mods
- After market cooler
- Power FC or equivalent
- full exhaust system from turbos back.
- boost increase with stock turbos
From reading these forums and from personal experience these mods on a RB25 with 10-12psi of boost ~200rwkw seems to achievable. I know the supra will make a lot more power than this but how much more?
Edited by Munna
  • Replies 46
Well.. when we were at the dyno day with OCAU a supra running pretty much the same setup except it was running a SAFC2 and a boost controller I believe.. he reeled off about 240kw..
Thanks thats about what I would have expected anyone else? What 1/4 mile times would a supra with these mods and a good suspention setup get?
My brother has a '95 Supra RZ with those mods, plus a Trust pod filter, Bosch 044, AVCR and a Malpassi fuel pressure regulator and is making 272rwkw at 14psi. He could be making a little bit more, but needs a new dump pipe.
"They taste like burning!"
The dump isn't stock; it's a 3 inch dump. But he was told that a 3" dump was too large for the stock turbos on a Supra as the wastegate can't control the boost properly (needs the back pressure). So he's had a restricter put into the dump until he gets a new one.
Got a friend who got there 1996 TT (6spd) Supra dynoed with the following setup:
1. Aftermarket Front Mount Intercooler
2. Stock Air box/Turbos/Boost setting 10psi or there abouts
3. Catback- OR turbo back exhaust (unsure)
4. 18" rims.
result:
214rwkw at unigroup.
2JZ-GTE into an R33 is stupidity in my opinion. 2JZ with the 6 speed costs an absolute fortune, and an RB26 can make similar power. If you really want the BIG CUBE straight six, you could probably build a killer RB30DETT for less than a 2JZ engine swap. The cost of installing a 2JZ would be phenomenal.
Keep a Supra engine in a supra, and an RB in a Skyline..
If you want extra power in a Gts-t.. go and buy an R32 GT-R than you'll even it up.. what a skyline lacks sometimes in raw power, it makes up for round the corners.. ATTESSA.. and a couple of other areas..
Personally I would love a Supra TT - but for 40k i'd be hard pressed to not buy a R33 GT-R..
They are definately quite a nice car.. I love the look of them.. so sleek.. with a set of rims, lowered with no wing.. droooolling..
Thanks everyone I know that the supra is quicker over the 1/4 than the r33 gtst from the factory.
How would a R33 GTS-T fare against a the supra both in street trim at this level of modification assuming they both have a decent suspention/tyre setup. Keeping in mind the supra weighs 200kg's more.
I know that the skyline is capable of high 12's what can the supra do?
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
