wouldnt you need a custom pedal box for a brake bias to work? or at least a custom adjustable master cylinder... check out somewhere like race and rally, they will probably have the pedal boxes/master cylinders?
what toyota has that? i know u can get an inline brake bias valve that will increase or decrease the pressure to the front/rear brakes but not a bias in the master cylinder, u would need to run a balance bar and two master cylinders for that to work...
Pretty much every Toyota has one.
The front and rear brake lines leave the master cyl, go to the bias valve (bolted to the firewall or strut tower), and then from the bias valve output to the front and rear.
Do you have a pic of an empty Skyline bay I can look at?
I've have a search around in the meantime.
Edited by CrUZsida
