  • Replies 85
R31_silo2: well.. I've got something in the works and it already has a comparable stereo gear. Curiously there are NO rear speakers... anyone seen this before?? I thought rears were stock.
race_snooze: well see, I coulda sworn I saw one that was white in my suburb and thought that was the one I was gonna check out, but this one was grey. So I might have seen yours, but I have nfi where you live :D
lol @ starting 32 vs 33 war
As for weight diff mines 1260kg so whats a 32 hmmm
what have you done to you R33 to make it 1260kg, as they came from the factory at a kerb weight 1370kg? R32's were 1290kg kerb weight from factory
Just remember guys, you can't get Milk and Juice in 2.5L
Just remember guys, you can't Milk and Juice in 2.5L
yea snooze you must have put her on a heavy diet as mine is i think about 1400kg's you got on anerexic skyline :blink:
Dunno if I got this right, but by comparable gear I'm guessing you mean like aftermarket? Having no rears is not unheard of, specially caus by the time you get your hands on a car with stock speakers they are usually shite.. thus if you cudn't afford both front and rear .. and wanted some good front ones (ie splits), I know I'd shuv the old out the door.
I dont have rear speakers in mine but the boot makes a good place for a pair of 12.5 Subs. Not putting in the rear speakers certainly helps the doof doof get into the cabin :)
Yeah. I just thought it was weird @ no rears. I don't send any signal to the rears in my Civic anyway (just fronts and sub), so I guess it just saves weight and no interference between 6x9's/whatever and the sub.
Mine subs only 10" and did the job in the Civic, hope it'll be ok in the line. I got 10" cos it was cheap and I like my metal so need a quicker response than 12".
I'm not quite outer belco snooze.
BTW: I made a post on car covers for skylines but noones answered :) guess everyone's lucky enough to have a garage (and not have a family of 4 with one car each!). Plus I'll have the civic until I flog it off so that's 5 cars. We have a garage but it's chockas so NOONE parks in there, what a waste...
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
