Looks lovely!!!
as much as it saddens me to say it i actually am starting to like new rear end... the new rear lights look different and it sad that its lost the circles but the lights definately compliment the rear end, especially on some of those 35 models that have the kits on them, some of them look schweeeet!
  • Replies 40
Posted Images
At last some better pics.
That G35 badge has gotta go to be replaced with the proper GT350 and Skyline badges.
All that is needed now are Fat wheels,coilovers,swaybars and mild bodykit additions
Looks lovely!!!
Circles are still there mate :) ...just
Congrats with new car :blink: Just one question, can you comply G35 in Australia yet? I've been asking around but the compliance workshop in Perth has no clue when it will be available :P
No you can't comply a G35 Eric
Yes the V35 can be complied but only in Queensland at present.
Other dealers will follow very shortly I'm sure
Eric if you need to trade in or sell your 34 first then I suggest you wait for a Perth dealer to obtain compliance approval as that would be easier.
I'll be going to the darkside :)
For Sale Soon
MY02 WRX
Lowered
Antilift kit
Rear Swaybar
Zorst
Panasonic HU/Amplifier/6stacker
1 owner
service history
Ecuteck 3 computer reflash
Twinlight conversion
Limited edition #34 of 100
WRC Blue :)
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
