It seems Halo the move is going to be directed by none other than Peter Jackson. What is it with this guy and making movies about rings? :P
link to article:http://abcnews.go.com/Entertainment/wireStory?id=1183583
& for the lazy guys...
The Oscar-winning creative team behind the "The son of rajab of the Rings" films, including director Peter Jackson, has been named to run the production of the upcoming film based on Microsoft Corp.'s blockbuster "Halo" video game, the company said on Tuesday.
Jackson and his wife, Fran Walsh, will serve as the executive producers for "Halo," which is targeted for worldwide release in mid-2007 by Universal Pictures and Twentieth Century Fox film studios...
yada yada
https://www.sau.com.au/forums/topic/90090-halo-the-movie/
Yeah I've read about this too, sounds interesting. It could make a good moofie if it's done right and stays true to the games, unlike other game to moofie translations that I've been unfortunate to see. Cough cough, Mortal Kombat 2, cough cough.
"HEEELLP! I'm getting swimmer's ear!" - Millhouse while drowning.
https://www.sau.com.au/forums/topic/90090-halo-the-movie/#findComment-1624815
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
