I decided to buy this model, Legalis R because its soo quite...
So i hoped!!....AND IT IS!! Its like, driving a std car with a little tiny tiny burble!! Infact, often engine/road noise out does the exhaust.
I cant feel much of a difference, thats probably coz i havnt installed the cat just yet, but mmm so happy
Link to Fuji website about my exhaust... http://translate.google.com/translate?u=ht...Flanguage_tools
Cant wait to put the cat and split dump in, will be fun :P
BTW, anyone wondering, i got it for 1100 airmail deliverd...
Edited by AlexCim
https://www.sau.com.au/forums/topic/90146-got-my-new-fujitsubo-exhaust/
  • Replies 58
NOOO should have got the power getter so i could see some pics installed.. damm u.. ahhaahh..
So you cant even hear the exhaust at all?? not even a tiny bit??
Is that the way you always wanted??
Edited by siddr20
Written at the bottom, 1100 air mail
I couldnt get the power getter for E-WGNC34, only this or the regaris. I didnt want the regaris as it was 94dB at 4800, this is 84dB
(to me, that is crazy low)
Plus, i am trying to keep the sleeper look/feel about the car, so this suits me perfect :P
Previous to this, i had a custom made catback with xforce muffler. For me(quite lover) it was quite loud, and the single cabin doesnt help when it comes to cruising at 2,000 at 80 for several KM's so yeh, quite is what i wanted.
Anyone that wants a cheap catback for a Stag, i want to sell this one
It cost me 590 to make, so make me an offer for it..
Edited by AlexCim
Wow, that exhaust looks almost identical to my one, but mine isn't as shiny anymore. maybe i've got one of those too. i can't hear the exhaust at all really unless i'm behind the car loading the boot.
looks really good though, congrats
Have a look under your muffler and see if it says FGK, if so, chances are you have the same exhaust
When i said i cant really hear it at all, i am not just trying about idle, i am talking about the whole rev range. At ~2000 you can hear a tiny tiny rumble, i think thats where it resonates most... apart from that, engine/road noise is the go with loudness
Cat goes in today! Ill post photos when im done
And here is the cat!
its a BOS importing stainless steel inside cat
The power difference for this exhaust over standard isnt HUGE, but its noticable. Its because i chose quite over powerful...
The boost is much stronger now, so is induction noise and also its spools really hard during hard gear changes. Power is a lot smoother too
Cant wait for the PFC and turbo upgrade... oh and the manual conversion :)
Oh, and to anyone wondering, the car sits 12cm off the ground at the lowest point, this is the bit just under the rear sway bar.
My car also sits at 405mm and 380mm F/R centre wheel to gaurd... soo i wont lower it much because then ill be illegal, so drop it only another ... 1.6cm (0.8cm adjustments when i get the shocks)
Yep
When i met up with Burns and he was complaining about the car being too low and hitting things, i thought, how could that be because the car looked PERFECT at the height it sits
What getting this aftermarket exhaust as taught me is that no one that will get a aftermarket exhaust can expect to sit too high off the ground. I wanted to drop the car to about 350-360mm, but now, i wont take it below ~370 because otherwise it will be
a) illegal
B) impractical (i still carry heaps of stuff too)
But still, i just the height of 370. Ill just fill it with some GTR wheels when i get around to it and it will be all sweet. I think PranK has std suspension and his GTR rims fill the gaurds perfectly.
On the Fuji website, it says that the exhaust causes the std car to drop to 13cm off the ground. Given sag/age, i think 12cm sounds about right
I know this is an exhaust thread, but ground clearance and ride height are important considerations when choosing an exhaust. So there is a mixture of exhaust and ride height dimensions that might come in handy following.
Before we get into it I should mention that I have raised mine 8mm (using the next up circlip groove) since the pictures where taken. It now sits at 345 mm centre of wheel to guard at the rear (350 mm at the front) and at that height the STANDARD exhaust is exactly 100 mm from the ground. That's measured under the rear stabiliser bar same as Alex's. At that height it just clears the local speed bumps that I usually use to check clearances.
Note that the front 350 mm and rear 345 mm gives a 10 mm rake (nose down) when measured at the sills. At 405/380 Alex's is sitting around 10 mm nose up, which is what mine was like when I got it. The 10 mm nose down makes a big difference to how it looks, much more agressive stance, so to speak. For the guys getting the Whiteline/Bilstein Group Buy kit that is 1 circlip groove up from standard, both front and rear.
The standard exhaust is ~2.5" (62 mm) OD, so a 3.25" (83 mm OD) exhaust is going to be 20 m closer to the ground. Even a 3" (75mm) exhaust is going to be 13 mm lower. I can't raise the exhaust up any higher than standard because it will hit the stabiliser bar. So I might have to go up another 8 mm in the spring height to give similar ground clearance to what I have now.
That will leave the front at 358 mm and rear at 353 mm (still with a 10 mm rake, nose down) which is 47/27 lower than where Alex's is at the moment.
:D Cheers :)
Edited by Sydneykid
Ill keep this thread updated when its my time to buy the suspension package too, my goal is to keep it perfectly legal...
Ill also update when i install the split dump/front in one, but i doubt that will sit any lower really..
Edited by AlexCim
Turns out i do have the same exhaust as you, but only form Cat back. i'll have to get the autosol onto it to get it looking like yours though, mine has been on there at least 2 years
I was the original stagea trialer for the SS split dump/front pipe
There was some problems with the angles of the pipe which are getting sorted now. Also, the o2 hit the exhaust manifold
I am just waiting on my revised pipe to arrive and then ill give it a go installing it again (was a bitch of a job the first time around .. but now i know what to do/how)
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
