  • 1 year later...
NOTHING WORSE THAN BOREDOM,CANT WAIT TO GET OUT ON THE ON THE ROAD ESPECIALLY L8 AT NIGHT.
CRUISIN WITH BUDDIES OR SOLO ALWAYS HAVE A BALL,OVIOUSLY THE MORE THE MERRIER.
LOOK FORWARD TO MEETING NEW CRUISING AMIGOS SOON,RIGHT FOOT IS STARTING TO ITCH. :(
https://www.sau.com.au/forums/topic/90149-cruising/page/2/#findComment-2681914
I love RNP from Wollongong upto Sutherland...
I'd never done the whole trip before until like 3 days ago, I used to bail out at Waterfall...
Love the top half of that run.
Most of it is done in 2nd/3rd gear (Not booting, just "spiritedly" using upto around 1/4 throttle... Then get out onto the fast moving corners, then back into the slow stuff as you near Sutherland... Mad fun!
I had a car see me coming through a few corners and as I approached, they pulled over, then pulled back out... LOL...
I think hitting some of those corners at the speed limit worries some of the public... :S
https://www.sau.com.au/forums/topic/90149-cruising/page/2/#findComment-2682423
i always see this old guy(almost 60) in a blue convertable turbo mx5
boosting up and down the highway every sunday.
if i live to 60,ill be doing the same but in my Line
I do the penrith jaunt a couple of times a week and see that old dude aswell wearing his grandpa hat :P
https://www.sau.com.au/forums/topic/90149-cruising/page/2/#findComment-2682681
That's the way to live - let's hope we're all that enthusiastic when we get older.
Was watching a few podcasts about the movie "Cars" and Paul Newman is still out there thrashing around at 81yo!
https://www.sau.com.au/forums/topic/90149-cruising/page/2/#findComment-2682718
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
