OK here's some better tips raceworx style. We have blown up so many engines we should have some ideas.
Fluids will go everywhere no matter how careful you are. Coolant out first and drain the oil from the engine...the engine shop dont need that surprise.
Assuming you are doing it in the garage, jack it up super high and leave it on 4 jack stands. Dont forget to undo the wheel nuts first if you are taking the wheels off.
Get one of those nifty organiser thingies like this to keep bolts organised, you will lose them or put them back in the wrong place otherwise. The longer until the engine goes back in the more bolts will escape
As discussed a lot of long extensions make it easier to get to the top transmission bolts. The harmonic balancer is a bastard to undo too. On a GTR a tiny little stubby ratchet or ratchet spanner make the top starter motor bolt much easier.
In a GTR as the engine comes out you will need to tilt the rear of the gearbox down so the input shaft stays straight. Undo the gearbox crossmember and put a jack under its rear to let it down as the engine goes up. Use your 5th jack stand to hold the gearbox in once the engine is out.
Dont take the power steer pump out just take it off the block. Same with aircon compressor. Alternator and starter motor you remove but dont lose.
Beer helps keeping things lubricated during the job.
And as the manual always says, assembly is the reverse of disassembly.
Thanks guys.
Are you saying Duncan, that I can't take the engine out without the gear box or just that there is not enough room to move it forward to get the drive shaft out without tilting it?
I will take the radiator out cos that's easy. Do you guys normally do that?
Why do I need to remove the harmonic balancer? I thought the engine rebuilding place would do that.
Put aside a minimum of 5days to get everything out and back in again.
I'm a bit of a fuddy duddy and bugger arse around abit though. :P
When I had everything out I also took pictures of everything, alternator, powersteer pumps, a/c.
Always comes in handy when something needs replacing and you need a part number or need to know what type it is. :)
Thanks guys.
You can remove the engine without the gearbox. There is enough clearance if you remove the radiator. Last thing you want is the engine leaping forward as it disengages the gearbox and punching a hole in the middle of the radiator. Support the gearbox with a jack first.
I always remove the front wheels then lower the car as far as possible when working over the top or the final engine removal which helps with the low ceiling. Saves the hamstrings from later pain. Remember to use stand when underneath of course.
Locate the engine lifter as far forward in the garage as you can so you can then use the jack to roll the car back or to the side if space around the crane is a problem. My garage is at the top of a steepish drive and the chain block is fixed in the ceiling so I just roll the car out of the way and mount the engine straight on the stand.
Otherwise, what Drunken said.
Adam ,
Take the radiator out , the first thing yopu will do . Dont forget to use a sheet of plywood or chipboard to protect the air cond condenser .
Dont bother taking out alternator , unbolt the air cond compressor and secure it on the rail do the same with the power steer pump that way you dont have oil spilled everywhere .
Undo the engine mount nuts ( from under the car ) undo the tranny bolts and the starter , then split the box using a huge screwdriver and or tyre lever . take the front pipe off but leave the turbo and dump on .
Mount you chain on the mounting hooks at the front and rear of the cil head .
The bonnet should be removed before you start , a bit in a hurry , if i forgot anything when you are about to remove it p.m. if you like or ring me and i'll try to help you .
No you dont have to remove the harmonic balancer , the engine builder can do it with a rattle gun easy .
P.m if you want my phone number .
You will be fine mate , you can do it .
Thanks for the added info guys. I've been collecting containers and boxes to put stuff in. :D
Thanks for the vote of confidance Jerry. I already have your number and I might give you a call if I get stuck but hopefully I'll be ok.
I'm going to pull the front bar off and remount my intercooler while the engine is away so perhaps I should remove the air con condenser while I'm there??
And do we have consensus on removing the rear gearbox mount/cross member? Ie; can I leave it connected to keep it all solid since the transmission is staying in? Is there enough room for the engine with the drive shaft sticking out to clear the bay? Obviously I'll support the front of the trannie.
When we did my engine conversion we had to pull the Neo out of the R34 halfcut, we didn't encounter any real problems to speak of that relate to what you're doing (Getting the loom out was an arse of a job but you're not going that far I hope :D)
We cut the radiator support panel out to assist in the removal of the engine but I hope you're not going to need to go to that level :)
As been mentioned before, get as much coolant out as you can, get the oil out, etc
If you intend on leaving the gearbox in the car then be prepared for an arsefight, I'd suggest just pulling the engine & box out together and putting them back in together, that way while the car's off the road you have the opportunity to do some cleaning up inside the transmission tunnel to remove the road grime etc if you feel so inclined :P
Everything else has been covered I reckon, have as many people around as you can when you're pulling the engine out to try and avoid it smacking the firewall or the radiator support panel
Personally i remove the engine much differently but you need access to a 2 post hoist and a nice solid metal trolley(i use a friend workshop after hours and pay for the use with cartons lol)
Basically past the car on the hoist and i drop the subframe/engine/gearbox out on the trolley and lift the car off the top
the last GTR i did in 3 hours by myself
once it is out of the car it is so easy to work on (would would even concider doing turbo change with way now)
i then remove the gearbox from engine and the engine out of the subframe and place the subframe back in the car temporary until the reinstall. The whole job from driving in the car, to pushing the car on the car trailer to take it home with motor and gear box on the back of the ute was about 4 1/2hours (by myself) i just had a couple of friends at the end to push the car around.
pete
4.5 hours? Geez that's good going Pete!
When I took my RB20 out it took myself and my brother from 8.30am until 4.30pm and half a carton of tooheys!
hehehe
yeah but i have done few this way now and you bypass all the problem points ie top of gearbox and starter motor bolts etc
my quoter was a 6 pack of the sphincter of the universe studdies lol
pete
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
