I hope you have a tranny jack , they are very heavy !
You can do it in 4 hours easy even if you never done a gtr before as long as you have done plenty others .
A couple of tips , lower the subframe say 10-20 mm so the whole engine box asssembly tilts to the rear , then its easy to get to the top bolts , the top starter bolt can be a bitch , its best to undo with a bendy spanner ( C shape ) .
Block the attessa pipe so you dont loose any fluid and dont forget to bleed it when you put it back in .
When its all undone you may have to rotate the box to fit through the tunnel to get it down .
