Any importer can bring in a 4wd if its older then 1988, however there are no new models of 4wd available for import under raws except for delica vans, and convertable pajeros so there is no way to import any newer 4wds legally. You cant bring in late model Surfs etc anymore.
Edited by JASSPEED
https://www.sau.com.au/forums/topic/90198-4wd-imports/#findComment-1626339
  • 3 weeks later...
  • 3 weeks later...
the auto whole sale in vic park has the mits spacegear. they all turbo dise. some og them even come with the cannon tip at the back!
the 2 door convertable pajero were imported under the old rule, not sure if any company is WA has the plate for it..but sure someone from eastern state hold the plate from memeory
https://www.sau.com.au/forums/topic/90198-4wd-imports/#findComment-1719398
  • 3 weeks later...
My old man has a 12HT landcruiser. the strongest engine toyota built, in his Landcruiser.
His model is 87 so you can still import them under the 88 rule.
They are damn nice cars on the inside. and the PTO winch is nice, my old man got a custom built bull bar made to concell it all. I can give you contacts to get one built.
If you get one, make sure you buy a 4x4 from the south of Japan. Advoid all 4x4 from the north where there is snow!
And you will get a ripper of a 4x4.
I can get you photos of what you can expect in a 87 model Landcrusier.
:P
https://www.sau.com.au/forums/topic/90198-4wd-imports/#findComment-1763145
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
