There has been a couple of threads on this in the last few weeks.
A leak down test is more informative than a compression test.
Also, it's more important that the compression is even than that it is a particular psi on a particular gaugue on a particular day with a particular battery level with whatever temperature the engine is.
All of those things affect the reading.
Thanks for your reply, i got the results in and the compression in each cyclinder is as follows: 90 75 90 75 90 90. The guys at the workshop reckon this is okay. But like you said its pretty even. So should this be a worry at all?
If the compression test was conducted properly (warm engine, wide open throttle when cranking) then those results are pretty poor and the engine is fairly worn out. I believe Nissan specifications say 130 - 170psi.
WHat do you mean by wide open throttle when cranking? This GTR also has a worn out clutch would that affect the reults at all?
Engine should be adequately warmed, fuel pump fuse taken out, throttle floored and crank engine until gauge doesn't move. 8 or so compression strokes.
from nissan manual
new 171psi
normal 160psi
limit 128psi
14psi max variance between cylinders.
I tested mine and got 175 175 175 165 170 173psi, 1992 GTR
It was higher than stock? Could it be from carbon in the cylinders increasing the compression ratio?
when i got mine tested 1990 GTR
i got 140 140 135 140 135 140
which is ok for one thats done 100k little low but even so...
and as far as i understand u dont wanna go below 130
i dont know the whole deal but those pressures dont sound good
good luck
RellikZephyr
I just had mine comp tested at Grey imports here in sydney. 190 highest and 180 lowest..maybe gauge was reading high? But still pretty even which is a good sign, nathan there said, no need for a leak down test, its pretty good.
after I rebuilt my gtst - which is practically the same so be quiet all you GTR owners - I had a reading of 120 140 130 160 80 120 when it was cold and a reading of 160 160 160 160 160 160 when it was warm.
This is how much of a difference it will make so get it checked when it is at operating temp.
I also have forged pistons so be quiet all you cast piston owners....lol
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
