There has been a couple of threads on this in the last few weeks.
A leak down test is more informative than a compression test.
Also, it's more important that the compression is even than that it is a particular psi on a particular gaugue on a particular day with a particular battery level with whatever temperature the engine is.
All of those things affect the reading.
Thanks for your reply, i got the results in and the compression in each cyclinder is as follows: 90 75 90 75 90 90. The guys at the workshop reckon this is okay. But like you said its pretty even. So should this be a worry at all?
If the compression test was conducted properly (warm engine, wide open throttle when cranking) then those results are pretty poor and the engine is fairly worn out. I believe Nissan specifications say 130 - 170psi.
WHat do you mean by wide open throttle when cranking? This GTR also has a worn out clutch would that affect the reults at all?
Engine should be adequately warmed, fuel pump fuse taken out, throttle floored and crank engine until gauge doesn't move. 8 or so compression strokes.
from nissan manual
new 171psi
normal 160psi
limit 128psi
14psi max variance between cylinders.
I tested mine and got 175 175 175 165 170 173psi, 1992 GTR
It was higher than stock? Could it be from carbon in the cylinders increasing the compression ratio?
when i got mine tested 1990 GTR
i got 140 140 135 140 135 140
which is ok for one thats done 100k little low but even so...
and as far as i understand u dont wanna go below 130
i dont know the whole deal but those pressures dont sound good
good luck
RellikZephyr
I just had mine comp tested at Grey imports here in sydney. 190 highest and 180 lowest..maybe gauge was reading high? But still pretty even which is a good sign, nathan there said, no need for a leak down test, its pretty good.
after I rebuilt my gtst - which is practically the same so be quiet all you GTR owners - I had a reading of 120 140 130 160 80 120 when it was cold and a reading of 160 160 160 160 160 160 when it was warm.
This is how much of a difference it will make so get it checked when it is at operating temp.
I also have forged pistons so be quiet all you cast piston owners....lol
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
