Guys;
Got a few questions on engine pipe design ie dump outlet to collector on a GTR.
Length
My understanding is that engine pipe runner length is not critical. A bit like after the headers on a n/a motor. However some manufacturers make equal length runners (with a big ass bend to create the equal length on the rear pipe) and others do shortest path. Nismo and Fujitsubo do both and the standard ones are shortest path. Others like Veilside go to amazing lenghts to create equal length. The rear pipe outlet radius on the equal length ones, due to the size of the bend, means the inluded angle on the collector seems too large.
Diameter
CES make good exhausts and they use 75mm or greater engine pipe diam on their comp engine pipes. Most manufacturers use smaller diam into a 75mm collector. CES swear that they get good results from going larger but can't say how much. Anyone done any testing?
Flex joints
I know what they do but there are designs that either use them or don't. I've not heard of anyone having problems because they didn't use one on a GTR, can anyone share their experiences here?
Regards
https://www.sau.com.au/forums/topic/90232-gtr-engine-pipe-design/
flex pipe is not as big a concern on a North South engine config like the GTR, but they are vital on a East west style engine like an evo etc as the engine rocks back and forward under hard acceleration and braking. they are still worthwhile having i reckon, as the side to side movement could still be a proplem without one.
as for the other questions, i'll be interested to hear some answers.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
