Here's what Bass Junky emailed to me one day.
I sent him the pic and he sent it back.
"Hi,
Looking at the photo, I will make an assumption that the top turbo is of an R34 GTT.
I have added a couple of little lines on the photo which illustrate the differences that I think there are between the R33 and R34 turbos.
The relationship between the width of the gap between the snail and the flange, and the width of the flange itself is a pretty good indication of the turbo.
R33 has a wider gap than the width of the flange, and the R34 or VG30 turbo has a gap which is slightly thinner that the width of the flange.
Does this make sense?
Cheers"
um was under the ausmption that 33 were cermaic but also ball bearing
SteveGTS4 pulled one off a series 1 GTST, and it wasn't ball-bearing. Noone is correcting either of us though!
Thanks to everyone whos read this and had an opinion, you've all been very helpful.
Cheers to you all. I'll report back and let you know what it is!!
Plus a power figure for my Stagea!! hahaha
(Got 141kw now at the 4wheels, putting on beefier fuel lines, fuel regulator & fuel pump, Z32afm, apexi sitc, apexi fmic, & neo turbocharger. Expecting 160+kw at the 4wheels.)
Brendan
Going by your info Abo Bob; damn it, the turbo I paid good hard cash for is therefore a bloody R33 turbo - which is what Ive already got!
Cubes: the thickness of the housing seems to be 45mm not 50mm. Suggests R33 not R34.
Man Im not happy!!! Just because its got a platic front wheel its been assumed & sold to me as a R34 turbo.
Add in with that the blowing fuses after the stereo install = no ABS or 4wd, and boy am I an unhappy person..... the auto electrician the car is with at the moment has requested me to supply him with the cars wiring diagrams etc!
Grrrrrr
Yup, will do, will take another photo asap.
Trying to get to A.T.S. here in SA to have it properly examined; if it is the R33 then I might as well start saving and hiflow it, then sell my current turbo of the Stagea.
Going by the thickness of the housing (45 not 50mm) and the thickness of the flange and distance from 'snail to flange' from your post, its gotten R33 written all over it.
Its so damn hard to get around the place to have things checked when you work too many hours!!!
and i have a curve ball
i recently bought another turbo. fairly certain its VG30 .. later model.
OP6 on the housing. very stumpy looking dump pipe but the compressor has 45V4 on it. seems pretty large from the measurements.
just thought i'd throw that up.
So if this R33 turbo measures up as 45mm thats the same as my rb20det turbo. :O
I remember discopotato stating the R33 turbines are slightly larger than the R32's. Is this really the case?
Angry, that VG30DET turbo, could you do a few measurements and post a pic of the compressor wheel?
It would be great if and when you rotate the compressor housing (as you have to do with the vg30det turbo's) could you remove it and measure the compressor wheel.
Being the 45V4 and slightly newer than the one I have it woul dbe interestering to see if they uprated the compressor wheels. The later model Vg30DET's made 206kw vs the ~190kw earlier models.
The Vg30DET turbo I have has the same compressor wheel as the rb20det turbo's, exactly the same. The only difference being the turbine and compressor cover is larger, obviously allowing for higher airflow.
Edited by Cubes
Well, Im still going to go the Adelaide Turbo Services and have it checked out (when I get a chance; they can do the piping for my new Apexi fmic with the C-bend behind the cooler, so that original pipeholes can be used).
Might start saving anyways and have the turbo rebuilt with steel wheels, I'll discuss that with the shop when I get there. Pretty much I want this turbo to give me around 30more 4wkw.
But if its no good, then Ive got 2 turbos to sell, and with the change grab a HKS 2535 off nengun! We'll see, not too sure what the plan of attack will be now......... will let you all know.
Guys, had Bill at Adelaide Turbo Services check out the turbo I bought. Its definately a series 2 R33 RB25 turbo charger and actuator. I got ripped off by a forum member who contacted me and told me he'd sell me his R34 Neo turbo.
Paid $650 for this turbo - although it is in very good condition, I got reamed as it is NOT a Neo turbo. Now Im probablt going to have to save up a further $2100 and do a GT30 internal fitout to it (next stage up from a GCG hiflow). But Im not happy about how this has panned out.
In fact Im 'upset' by the fact that a forum member would go out of their way to contact me saying they've got a Neo turbo from a R34, ask good dollars for it as if they are doing me a favour, but yet not do the research to determine whether it is in fact a Neo turbo.
To all of you others, thanks for your posts and extremely helpful information that you've kindly supplied me.
EDIT: oh well, thats how its goes sometimes.......
Edited by bwilkeson
Yah, I sent a long txt message asking for a chq to be sent to me..... I received a heap of calls afterwards but I couldnt bring myself to talk to the seller - was just too angry.
Fact is, Ive got a SII R33 turbo on my Stagea, I have no need for another! Buyer beware I guess.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
